502 BBF
5pointslow
68galaxie
502 BBF
502" BBF Carb to Pan
DOVE-A block (with the Boss 429 bulkheads)
Offset ground early crankshaft - 4.15" stroke / 2.20" journals
Crower connecting rods 6.535"
Venolia custom pistons 12.6:1 CR with 75cc chamber
Canton T style road race oil pan
Ford Motorsports A429 cylinder heads - ported at AMS (flow figures available if wanted)
Ferrea Competition Plus valves 2.19/1.76
Victor intake ported (flow with intake manifold attached if wanted)
1100 cfm Pro-Systems carb
MSD billet distributor
Comp cams solid roller camshaft FF2235R / 1962R 111LSA 278/290 @ 0.050" 0.454"/0.450" lobe lift (2015 installation)(Lem Evans Camshaft)
Spare Crane solid roller cam R-276/4334-2S-10 110 LSA 276/286 @ 0.050" 0.4334"/0.427" lobe lift
Crower HIPPO solid roller lifters - replaced non pressure fed crower lifters in 2015 - and new CC solid roller cam installed
PSI 1224 valve springs (2021 installed)
Spare Manley 221424-16 springs (all check good on pressure test)
Manley Ti retainers
T&D shaft rockers 1.75:1
Manton pushrods
Edelbrock water pump
LSM valve spring removal tool (for use with T&D rockers)
$6,500 USD
Located in Edmonton, AB
Manley Ti retainers
Manton pushrods
$6,500 USD
68galaxie- Posts : 349
Lem Evans likes this post
Re: 502 BBF
That's a bargain for that engine are the Pistons Flat Tops?
Mark Miller- Posts : 1895
Re: 502 BBF
The pistons are custom Venolia forgings. Small dome (~0.060" high I recall)
Re: 502 BBF
wish you were closer
5pointslow- Posts : 1401
Re: 502 BBF
4.39" bore 4.15" stroke 72cc head, .041"/4.5" head gasket straight flattop no valve relief or dome, .000 deck comes to 13.45/1. Just saying. Mid 14.42/1 with 6cc Dome.
That is a very nice engine. ABlock with Boss bulkhead to boot. Great Price.
supervel45- Posts : 4460
Re: 502 BBF
5pointslow wrote:wish you were closer
You should check the pallet shipping. If everything is in order it might be worth it?
Just the top end is worth 3-3,5 w/o rockers. The T&D shaft rockers add big coin to the package. Probably over 2 grand.
Re: 502 BBF
The pistons had intake and a small exhaust relief.
Plenty of clearance measured with the 0.780" cam.
Putting the original 390 engine back in - 500 hp build.
The 502 was way, way too much for a street driven car (and 5200 stall converter)
Ran on 108 octane fuel - <20 liters per year. Maybe 10 to 15 miles per year.
Re: 502 BBF
^ I did not mean anything about valve to piston clearance.
Glad you brought up the 2 valve relief's though.
I was just pointing out that the stroker crank and 72cc heads raises the compression some over what may be listed sometimes from the manufacturer, is all.
6cc worth of valve relief's on a flat top comes out at 12.61/1 with no pop up.
If the pop up cancels out the valve relief's, to 0cc's, it will be at 13.45/1. If they don't it will be higher.
Whatever the compression is in the above ranges, if those heads are flowing good, I can see it making a lot or HP with those cams and a great, Deal in 2023 Dollars, especially with a $500 dollar roller cam thrown in.
Re: 502 BBF
With the 75 cc chamber and 0.010" deck height the CR is around 12.68 (assuming the small dome cancelled out the valve relief cc's.
I looked up the flow testing:
Head flow (int/exh) :
.2 152/117
.3 237/160
.4 296/200
.5 325/224
.6 358/244
.7 374/257
.8 388/261
.2 152/117
.3 237/160
.4 296/200
.5 325/224
.6 358/244
.7 374/257
.8 388/261
Re: 502 BBF
^12.68/1 on the money with those numbers, true. That's some nice flow numbers for the CobraJets. Likely in the 800 to 840HP range I bet.
Re: 502 BBF
Excellent deal. I sitting here talking myself out of a road trip for an engine I don’t need.
J.Toney- Posts : 397
Re: 502 BBF
^ I think you need to go get it. I am seprized he still has it.
Re: 502 BBF
pm sent if you still have thanks68galaxie wrote:502" BBF Carb to Pan
Manley Ti retainers
Manton pushrods
$6,500 USD
maverick172- Posts : 200
Re: 502 BBF
Sale pending.
J.Toney likes this post
Re: 502 BBF
Gone to a new home!
Re: 502 BBF
Someone got a great deal on that engine i just looked at the pictures again and seen the shaft rockers making it an even greater deal!!
