pressure plate completly flat
are pressure plates supposed to be completly flat..? laying a flat edge across the surface shows a flat surface from outer edge to about 3/4 in and then tapers off to the inside. taper is consistant around the plate at about .011 and disc shows the wear pattern that would be expected from that.
ragtime- Posts : 36
Re: pressure plate completly flat
Ive never heard of them needing a taper. Is it an after market high performance clutch?
stanger68- Posts : 490
plate
[quote="stanger68"]Ive never heard of them needing a taper. Is it an after market high performance clutch? [/quote
Needs to be flat, not really sure how the taper started. Possibly not machined correctly when new.
ragtime- Posts : 36
» Most Flat Tappet Spring Pressure You've Gotten Away With(Mechanical)
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» Pressure plate bolts
» Clutch & Pressure Plate
» McLeod 12" Flywheel, Pressure Plate, and Clutch Disc For Sale ***SOLD***
