55 staight axle swap 02 ranger ifs donor truck
fordsbyjay
Fat Fender 460
New stuff
Old stuff
first cut of the the old frame
new section added just a little fine tuning and welding to be done.
Defiantly will be lower that before.
OH YA the 35 are only for rolling it around in the shop. I will not be running them.
Fat Fender 460- Posts : 45
Re: 55 staight axle swap 02 ranger ifs donor truck
That looks like a cool swap. I have been eye balling my daughters Explorer for measurements for my 56 2 dr sedan. Another cool swap is using the crown vic front end in the 70's F150's.
fordsbyjay- Posts : 8
i looked at doing that swap for the 55 but the width was a little to much. I will keep the projected posted as i go.
Lookin good John, I need to come down and check it out.
Happy New Year
Happy New Year
The old motor mounts looks like 3.0 motor mounts you will have to pull the springs off to get to the nuts that hold them on or use a torch as I did on my ranger. You will need the mustang swap pan bigblok86ranger on 460 and I think he is on here to can tell you more on how to put the 460 on that front clip as he put 1 in his. I move my enegine back 12" so I want be much help on that part.If yours had the 4.0 in it you should have the heavy springs mine was a 2000 with ex cab xlt and it had the heavy spring already. If you can look in the door that your front clip came off you can see with springs yours has.Good luck on your builg have done the front end swap on a 37 internal truck with a chevy z28 front end .
springs
the springs are for a 4 cylinder but i can get the v6 spring if i need them. i hope i can get the steering shaft down to the rack the frame comes through exactly where the steering column is, oh well only minor details.
I like it. Keep us posted.
jbozzelle- Posts : 3705
I know what you mean on the steering shaft I had to reroute mine alittle your come out at the bottom that might be alittle harder
https://www.facebook.com/album.php?aid=8763&id=100000246841066&l=79fd6f1a6d
here is all of the pics that i have for the truck so far i will be working it tomorrow.
I like the fact that it gets new front end I just don't like it being # 300 lbs heavier, I think I would have built it all on the old frame and figured a way to adapt the suspension to it....
the Coug- Posts : 3055
old frame vs new
the new stuff with out the tires was not to heavy i picked up and unloaded by myself out of my f250, i was surprised that it was not that heavy. i can just barely drag the old axle around the garage with the old tires and wheels on it. I cant wait to take it for a drive it will have to be better that what i had. when i tact it in i lengthened the wheel base by 4 inches or so because i want to move the fender well forward late when i do the body work.
motor wont fit
i got everything welded up today and test fit the motor and guess what it wont fit down in the truck. I guess i will have to make a tunnel to get it to go in the frame. Any good ideas what to make a tunnel out of ? something quick and easy.
16 ga sheet metal mild steel work good that i have found and you can form it farly easy
old parts
If you are looking to sell your old steering box, please let me know, I have a friend looking...Thanks, Greg blown473
blown473- Posts : 376
steering box
the orginal steering box was already gone they had mount a power steering box in the old frame. sorry dont have one for him if i did he could have had it. let him know i have some factor stuff for the front. spindles brakes and cross members i cut out the rivets and removed it and the springs.
new solid mounts for the old truck passenger side
This was the only bolts i had at the time.
drivers side.
had to install some spacer between the sway bar mount but have penty of clearance now. Also got the frame out wide enough to fit through the front clip.
Your a workin fool John Looks like you'll be smokin the bologna rinds 4 long
bbf-falcon wrote:Your a workin fool John Looks like you'll be smokin the bologna rinds 4 long
steering and a trans cross member with be the next on the list after boxing in the rest of the frame.
i will try to get with u tomorrow on the exaust.
boxed in the cut out for the oil pan
better pic of the cut out and mounts
new steering linkage for the rack.
new steering wheel angle and height. Still might have to shorten the shaft a little after some seats.
Looks good.
You may want to consider incorporating some rubber mounts on the motor, since its a streeter. JMHO, even though knowone asked!
Regards.
Al
Regards.
Al
72mav- Posts : 1081
I had to notch mine to
» rear axle swap and pinion angle
» 2002 axle swap into 92 diesel
» 4x4 front axle swap question
» soilid axle swap f250
» axle swap f350 to Bronco
