My build, my Fox transformation....lotsa pics
Page 2 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Re: My build, my Fox transformation....lotsa pics
Post  bbf-falcon on Sat 1 May 2010 - 13:10
Lookin really good Mike,Looks like you are getting yourself ready for some SnakeJelly Cool
Post  bigblockfox468 on Sat 1 May 2010 - 15:49
Thanks Damon. On the not tightening of the tranny mounts bolts....is it cause since the engine and tranny are solid mounted I may break a trans case?
bigblockfox468
Post  bigblockfox468 on Sat 1 May 2010 - 15:51
Thanks Rick, maybe next year I'll be able to bring it to the Bash and play too Twisted Evil
bigblockfox468
Post  nuclearcobra on Sat 1 May 2010 - 20:31
Its because the engine is solid and yes it will break a case or housing.
nuclearcobra
Post  bigblockfox468 on Mon 10 May 2010 - 8:31
Well ...hopefully this is the last time the mock up engine had go in Rolling Eyes . Got some more accomplished. Here's some new pics.
It may be kind of hard to see the clearance I'm attempting to show that I have between the body/frame to the headers but believe me there is alot.
After the engine is in I can actually put the left header on from the bottom. The right header I put between the strut tower the midplate, drop the engine in and pass the removable tubes up, bolt them into place.....piece of cake Twisted Evil
bigblockfox468
Post  bigblockfox468 on Mon 10 May 2010 - 11:06
The limiter bars we created plus they're adjustable Smile
bigblockfox468
Post  GTmustang on Mon 10 May 2010 - 16:04
Mike: Look's like your making progress on the chassis and drivetrain. It's all a big can of worms, even when you think you've got everything figured out and then you run into something that won't fit! don't you just love it!
Gary
GTmustang
Post  bigblockfox468 on Mon 10 May 2010 - 16:21
I hear ya Gary,tell me about it Rolling Eyes boy oh boy lol! But I'm getting it Smile
bigblockfox468
Post  bigblockfox468 on Mon 10 May 2010 - 20:05
Did a little more work to the headers. Added the collector back to factory length, put some collector flanges on with some turn downs and got the evac bungs installed.
Had to notch my nicely fabbed trans crossmember for pipe clearance Neutral but it turned out okay. Cut where needed then boxed it in and added material on top for strength. She's coming along....slow but surely Wink
bigblockfox468
Post  Northwest outlaw on Mon 10 May 2010 - 20:52
Looking good keep up the good work.
Northwest outlaw
Post  '65 T-BOLT on Mon 10 May 2010 - 21:36
X2! keep up the good work!if you install one bolt a day! you will be that much closer to getting it done!
'65 T-BOLT
Post  bigblockfox468 on Tue 11 May 2010 - 20:52
Installed the radiator for a trial fit
Repositioned my auxiliary trans filter. It used to mount on that right side radiator bracket and also repositioned my trans cooler, no pic to show of that.
bigblockfox468
Post  bigblockfox468 on Mon 17 May 2010 - 9:54
Got my new shifter.... that I got from Joes Race Parts installed. It had a 1/4 stick in it but I wanted the pistol grip type. The new one sits a little different than the old one scratch . The front lever would come in contact with the radio and the shifter wouldn't lock. So the center console was removed, along with the radio and I plan on removing the heater control.
I kind of liked the center console look, but oh well you got to do what you got to do. The console alone weighed 12 lbs. I believe I've taken close to 100 lbs from the car. The exhaust that was on it weighed in at 44 lbs. I'll have to do a re-weigh once the new mill is in which will have alum heads opposed to the d0ve c's that were on the old engine.
bigblockfox468
Post  Northwest outlaw on Mon 17 May 2010 - 10:23
looking good like the shifter im still in the air on that or the prostick.
Northwest outlaw
Post  bigblockfox468 on Wed 19 May 2010 - 6:51
A panel was made and installed where the heater control was at. The color isn't off as bad as the picture shows.
bigblockfox468
