Used Engine Parts for BIG Engines . . . .
Used Engine Parts for BIG Engines . . . . Empty Used Engine Parts for BIG Engines . . . .
Post  gryphon68 May 15th 2010, 2:25 pm
Prices do NOT include SHIPPING.
Complete set of (8 ) BME 6.700 Aluminum Rods, 426 Forgings. 0.990 Pin, 2.200 Journal. Not many passes on these. $350
Used Engine Parts for BIG Engines . . . . P1010036
(7) Aluminum Rods believed to be GRP. 6.700, 0.990 pin, 2.200 journal. Approx 50 passes. Rod #8 available but had a bent pison pin, so small end needs to be honed to oversize. $100 for the entire set.
Used Engine Parts for BIG Engines . . . . P1010035
Comp Cams BBF Roller Lifters, full set of (8 ). Usable, but legs are slightly flared (0.001-0.0015") around the roller pin. Approx 50 passes. $120
Used Engine Parts for BIG Engines . . . . P1010034
Set of (Cool 3/8" Intake Push Rods for C460 heads. Not sure of exact length, can measure if interested. $40
Used Engine Parts for BIG Engines . . . . P1010033
Comp Cams 948 Triple Valve Springs. Used, Complete set of (16). 2.100 Installed Height, 1.645" O.D. Seat Pressures were down a bit, probably fine for use on a smaller roller cam. $100
Used Engine Parts for BIG Engines . . . . P1010032
4.600" Bore Venolia Pistons, Flat Tops, where in BBF w/ 6.700 rod. Number on the piston is 434. Not sure what cylinder head there are really for, possibly stock valve arrangement, could probably be fly cut for additional valve clearance, or run them way down in the hole for low compression engines. (6) are fine for reuse, 2 are NFG, one had bent pin, the other has the skirt kicked in slightly. $100 for all.
Used Engine Parts for BIG Engines . . . . P1010030
Used Engine Parts for BIG Engines . . . . P1010027
*NEW* BME Aluminum Rods. All 426 Forgings. (4) 6.700 Rods. (2) 6.800 Rods. All are standard 0.990 pin and 2.200 journal. $75 each for singles, $60 each if you buy all 6.700 or all 6.800's . . . .
Used Engine Parts for BIG Engines . . . . P1010026
gryphon68
Used Engine Parts for BIG Engines . . . . Empty Re: Used Engine Parts for BIG Engines . . . .
Post  90 lx coupe May 18th 2010, 7:55 pm
gryphon68 wrote:Prices do NOT include SHIPPING.
90 lx coupe
Post  gryphon68 May 19th 2010, 8:19 am
Complete Set of ( 8 ) BME Rods ($350) have been sold, everything else is still available.
If someone could remove all the picture in 90LXCoupes' quote it would be appreciated. Makes my For Sale thread hard to read.
gryphon68
Used Engine Parts for BIG Engines . . . . Empty sorry about that
Post  90 lx coupe May 19th 2010, 8:19 pm
sorry about that
90 lx coupe
