Anybody need any weeds burned?
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
I can handle it if you need to get rid of the pesky trackside weeds.
Got my car back from the chassis shop. Whole list of stuff done. Headers included. I would have liked them under the car, but no way the 4.5" collectors would fit without dropping the ground clearance to about 1.5". Like this I have 3.5" and it will help get the alky fumes out from under it.
More pics to come.
More pics to come.
David Cole- BBF CONTRIBUTOR
Re: Anybody need any weeds burned?
Gonna be hard to keep the car clean. Especially in the dirt or gravel. Before you get them coated you might want to see if he can turn them out through the fenders. On another note it should deaden the sound very well though. JMO, Don't take it the wrong way, just that I have seen first hand how clean you kept the dragster and I don't think your gonna like the dirt and dust on and under the car.
http://autofabcart.net/stainlessfenderexitheadertrim.aspx
TravisRice- BBF CONTRIBUTOR
Yeaahhhh maaaaan I'm gonna light a big fatty off of that one...
bb429power- Posts: 2741
exactly how mine are gonna be done......but in 4" lol.
richter69- Posts: 8200
looks nice David
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
I like it,Donna will like it bettr now you can do all triming around the house!
dr's wife racing- Posts: 516
Thanks guys,
Took some more pics today. See this thread:
http://www.429-460.com/proven-builds-f4/back-from-the-chassis-shop-t7474.htm#87884
Travis,
We considered turning and goign through the fender, but the entire factory A pillar is behind that little bit of fender. A lot of hassle and might weaken the car. I may see if I can find some 90° turnouts. Cut the collector 2-3" up and weld the 90°. Problem is finding a 4.5 90° with a tight radius. Lot's of 4 and then 5". All the 4.5" 90's I have found so far have like and 8" radius and are too big. I realize it will kick up dust, but luckily 90% of my racing is at my home track which has the entire pits paved.
TravisRice wrote:Gonna be hard to keep the car clean. Especially in the dirt or gravel. Before you get them coated you might want to see if he can turn them out through the fenders. On another note it should deaden the sound very well though. JMO, Don't take it the wrong way, just that I have seen first hand how clean you kept the dragster and I don't think your gonna like the dirt and dust on and under the car.
Travis,
Problem is finding a 4.5 90° with a tight radius. ;quote
any semi truck shop should be able to get it for you
BOSS 429- Posts: 1514
I don't think I've ever seen a pipe that dia with less than a 8" radius. 4.5" is not a very common deal at all, once you hit 4" the diameters tend to go in whole inches. I waited for over 3 months for a common 4" exhaust pipe for my sprayer. You might try to find a pipefitter that works with stainless steel, sometimes they have some off the wall stuff with small radius bends.
Big Daddy has spoken
Proud founder of the Truck Mafia
Definately in favor of God and guns
schmitty- Moderator
I definitly appreciate the offer, I do all of my own weed burning. LOL.
John G- Posts: 49
David,
I would highly recommend that you put some turnouts or back a little on it. If you can find a 5" turnout with the bend radius that you want, you could cut a section out of it and weld it back together. The circumference of the 5" tubing would be (3.14x5.0") or 15.7" and what you want is 4.5" diameter so that would be (3.14x4.5") or 14.13", so you would need to cut a sliver of about 1.5" and then weld the seam back up. You could use some large hose clamps to pull it the seam back together and keep it round.
85montess- Posts: 45
Tight radius 4.5" bends
http://www.pro-werks.com/categories/843/
Try these folks.
Try these folks.
wowens- Posts: 34
Thanks guys.
I talked with Tim Murphy at the The Fab Shop Headers today.
http://www.fabshopheaders.com/
Tim is going to make me a set of slip on turnouts. I'll cut the collector a little shorter and hopefully the low point will still be around 3.5"
Dave,
Just an idea, See if Tim can do a round 4.5" to oval 4.5 outlet. This would probably give you a little more ground clearance judging by your pictures Dave. Everything looks good on the car including the headers, Just don't see you being happy with the dust and dirt blowing all over your nice car.
Travis
http://www.pro-werks.com/partdetail/C76-572/ 4 1/2 donut
Travis
David Cole wrote:Thanks guys.
You went to the right guy. Tim is making my zoomies at some point in time. His shop is just a short hop and skip from Andy's
JS
jsracing- Posts: 338
Page 1 of 2 • 1, 2
Page 1 of 2
