generator?
+11
Diggindeeper
DFI429
BigDave65
valleydawg
'65 T-BOLT
15 posters
Page 1 of 2
Page 1 of 2 • 1, 2
generator?
i'm looken to buy a new generator for this year.the old coleman has about had it and i've about had it with it too. my trailer has a roof air but i never used it so all i'm needing is lights and a charger.the winch is 12v.looken at the honda and yamaha or even a used onan from a rv. opinions?
Re: generator?
honda!
'65 T-BOLT- Posts : 1464
Re: generator?
what size? 2000?'65 T-BOLT wrote:honda!
Re: generator?
that would probablly work...ours is a 4500 watt!...big one for the house...for bad weather...we just load it up in the truck and take it with us
Re: generator?
When I bought mine about 8 yrs ago I wanted one of the super quiet Honda generators. Wasn't in the budget though. I bought a Honda powered generator instead. It falls about 1/2 way between one of the quiet all Honda units and your typical Briggs/Tecumseh powered generators as far as noise. You can find them and they are powered by the Honda GX series OHV industrial engines. Mine has the 6.5 hp GX 200. 8 yrs old no with nothing but oil changes once a season, one air filter and couple of spark plugs.
Mine is very similar to this:
http://www.brandnewengines.com/ch350is.aspx
Caught it on sale for about $500. At 3500 watt's it's big enough to power everything I need at the track. Air compressor does tax it a little. I can also use it at home during a power outage. It can run lights, tv and fridge. Microwave as well if I turn some other things off.
Re: generator?
yep! double duty usage!David Cole wrote:When I bought mine about 8 yrs ago I wanted one of the super quiet Honda generators. Wasn't in the budget though. I bought a Honda powered generator instead. It falls about 1/2 way between one of the quiet all Honda units and your typical Briggs/Tecumseh powered generators as far as noise. You can find them and they are powered by the Honda GX series OHV industrial engines. Mine has the 6.5 hp GX 200. 8 yrs old no with nothing but oil changes once a season, one air filter and couple of spark plugs.
Re: generator?
the little honda 2000 deal was what i'd noticed at the track,i did'nt even know it was running.i've been checking craigslist and found a 4000 honda out of an rv. i have a 10'000 watt welder/generator for home use but i'd love to sell it if i buy a fair size generator.
Re: generator?
onan deisal is quite in a 10kw it is about as guite as the honda, the honda gas is is the quitest i have seen
Jim
Jim
Re: generator?
I have an Onan diesel on the RV and it is nice and quiet but on the trailer I have a 6500 McCulloch and it is loud. (Don’t park by me at the Bash!) I had a Honda once and it was quiet. I need to break down and buy a Honda.
valleydawg- Posts : 427
Re: generator?
couldnt afford the honda or the onan deals , so i got a 6250 coleman had it for 4 years and runs great
Re: generator?
I have a 5500w Honda, its not super quiet but it wasnt a million bucks either. It had a 2 gal tank which blows so i built a 12 gal deal for it................can run for 2 days without filling. It is an air cooled deal so I put it on a slideout otherwisw it prolly would over heat in the compartment.
Re: generator?
I have a Honda-powered gen. 4500 watt. I bought this thing in 1995 or 96 and have done nothing but oil changes, a couple of spark plugs and a fuel filter. I've always used synthetic oil. Like Richter said, it's not super quiet but it wasn't terribly expensive either. I couldn't even begin to guess the number of hours it has sat and just run and run. Powered the house for 3-4 days on a couple of occasions. It's still going strong.
It'll probably blow up now that I bragged on it!
BigDave65- Posts : 567
Re: generator?
richter69 wrote:I have a 5500w Honda, its not super quiet but it wasnt a million bucks either. It had a 2 gal tank which blows so i built a 12 gal deal for it................can run for 2 days without filling. It is an air cooled deal so I put it on a slideout otherwisw it prolly would over heat in the compartment.
Like Jon said if you have a air cooled gen the portable type you need it on slide outs to pull it outside of the compartment,if not it can run hot and explode in the gen box.I have seen this myself from where a guy brought his trailer in to get it fixed it exploded blowed up the compartment and burnt the side of his trailer and inside wall.Was like $4500 to fix his trailer and replace the gen just something to think about.
Jim
Re: generator?
i think i'm gona go look at this ev4000 honda.it came out of an rv but i dont know if its air or water cooled.$500 on the local craigslist.
Re: generator?
I run green oil in mine as well, just a little FYI............
Re: generator?
http://sportpacportablepowergenerator.wyinc.ru/tag/spgg750e/
Steele brand.
I bought this last fall new $500.00 new here locally. It is very quiet, but I have yet to run it loaded heavy. Electric start and a big fuel cell.
Steele brand.
Re: generator?
richter69 wrote:I run green oil in mine as well, just a little FYI............
Lol!!
It's funny... When I first met my chassis guy way back when our first transaction resulted in me fixing his Onan generator on his '86 Ford-based camper that he towed the Maverick with. Camper was 460 powered, of course Every time he'd fire anything up that needed current (AC, etc.) the genset would just laugh & cough... Turned out the generator lost one winding in a phase that I was able to pull enough wire to re-bond and return it to full capacity
Re: generator?
if you just need a little guy I like the makita I have at work. Its new so time will tell....and i dont know who manufactures it for them.
Onans are nice, but Honda is tough to beat.
Diggindeeper- Posts : 800
Re: generator?
damn snake,you gona power some stuff with 7500watt! hell i'll just plug into your "power grid".IDT-572 wrote:http://sportpacportablepowergenerator.wyinc.ru/tag/spgg750e/
Steele brand.
Re: generator?
cool40 wrote:damn snake,you gona power some stuff with 7500watt! hell i'll just plug into your "power grid".IDT-572 wrote:http://sportpacportablepowergenerator.wyinc.ru/tag/spgg750e/
Steele brand.
He had a 6500 just like it when I bought mine................ if your interested, or your more than welcome to hook up to my grid..........
Re: generator?
Dang what happened my reply is in the middle of your quote.................
Re: generator?
i went and looked at the ev4000 honda but i just would'nt up for mounting it on the trailer,riggen up a gas tank for it,etc etc....i realy dont need a big one for lights and a charger.i'm realy looken hard at the eu2000 honda or the little yamaha.
Re: generator?
I have had a Honda EU3000, then a Honda EU6500 as well as the little EU1000 all are very nice. Quiet, reliable and compact. Initial outlay is higher than a lot of others but worth it in my opinion.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Re: generator?
If you wont a Quiet gen. just neck down a small 2" walker oval muffler to fit it I use to do it on chain saws, you cant even tell its running.
res0rli9- BBF CONTRIBUTOR
Re: generator?
res0rli9 wrote:If you wont a Quiet gen. just neck down a small 2" walker oval muffler to fit it I use to do it on chain saws, you cant even tell its running.
INTERESTING
Page 1 of 2 • 1, 2
Page 1 of 2
