Boss 429 questions
Boss 429 questions
Guys I have a friend who is putting together a Boss 557 with a blower for a guy and he needs a couple parts and questions answered. If you can just reply to the post I will forward the answers. Thanks Tore
Water manifold kit for Boss 429 - connects into the front of the
heads and tee's into the upper radiator hose / All the NASCAR 429 engines
had this arrangement, so there must be some out there from somebody
2) I have the small diameter MSD distributor(429/460/351C) , but may need
a crab type cap arrangement for clearance with the BDS blower snout does
MSD make a special cap for this application ? Can this be done without
using the trigger up front of the engine ? See if anyone has anything .
I would like to use the present distributor, but may not clear .
Tore- Posts : 862
Re: Boss 429 questions
Tore wrote:Guys I have a friend who is putting together a Boss 557 with a blower for a guy and he needs a couple parts and questions answered. If you can just reply to the post I will forward the answers. Thanks Tore
Tore,
In regards to question #2. To the best of my knowledge, there is no crab cap available that will fit the MSD small diameter distributor housing. There are several different height distributors from both MSD and Ford Motorcraft that will fit, just make sure that the proper dist. gear for the 429-460 is on the distributor.
I make an adapter in order to use the Mallory crab cap on the Ford Motorcraft distributors and that may be an option for your friend.
Charlie
c.evans- BBF VENDOR SPONSOR
Thanks Charlie. I thought I saw something on here one time about that. I will forward the info to him. Tore
Tore- Posts : 862
Theirs a Boss 9 guy in Spokane Washington that may have the Water kit your looking for.... I'll look for a link. if not have you looked at the ones for Cleveland / SVO heads from companies like CHI?
This guy may be able to help, Ask for Reproduction parts, Origional Stuff is VERY EXPENSIVE from a dealer like this.
http://www.bossperformance.com/parts.asp
dfree383 wrote:This guy may be able to help, Ask for Reproduction parts, Origional Stuff is VERY EXPENSIVE from a dealer like this.
Thank you Tore
Tore- Posts : 862
you dont want to use a crank trigger? they are the shortest dist
BOSS 429- Posts : 2368
Kasse sells the CHI water kits!
'65 T-BOLT- Posts : 1464
» questions on the boss 9 heads
» 460 fox questions
» A460 intake tq spec
» Few questions about C6
» Cam questions
» 460 fox questions
» Cam questions
