Water proofing motor
f250mike
digger460
You guys have any tricks for waterproofing your engines?
digger460- Posts : 84
Re: Water proofing motor
You can run a snorkel from the air cleaner through the firewall to prevent water from getting in the engine, and silicone the distributor cap base to prevent water from getting inside the dizzy, then wrap the top of the cap and wires in an old inner tube or some other water proof material to shed water. Those are the ones I've seen and they do help.
schmitty- Posts : 4538
We use to ice down the beer and wrap the ice bag around the distributor.
For the carb we made a new breather top that covered the filter on the front and sides.
Also made a rubber flap that bolted to the front bumper. It hanged down to the ground and fit between the tires. When in deep mud it would fold back and cover up the area between the radiator and engine.
f250mike- Posts : 628
For the distributor get the factory ford cover they used on lincolns in the 80's they work great and are easy to put on and take off as needed
lghting94- Posts : 762
Seal the dip sticks and run tubes from all your vents (Trans and engine breathers) to above any possible water too.
Make sure to seal all electrical connections and use a bunch of dielectric grease.
Outrun the water, that's the easiest way!!!
crittersf1- Posts : 521
you should have a dizzy boot by monday or tuesday if off a 91 t bird lx with a 5.0 ho I had years ago
69F100 wrote:you should have a dizzy boot by monday or tuesday if off a 91 t bird lx with a 5.0 ho I had years ago
Thanks Jim...I am not in any hurry for it. I have plenty of Wal-Mart bags. Let me know what you are going to need for it.
A thank you when you get it.
Thanks again Jim for the free boot and shipping. A couple weeks ago I did the same thing for someone...so I guess as the saying goes"what goes around comes around" is true.
The rubber boot will look way better than the plastic Wal-Mart shopping bags
Last edited by digger460 on June 27th 2011, 7:43 pm; edited 1 time in total (Reason for editing : ...)
Glad I could help you out yes I believe what goes around will come around help a brother or sister when you can and most of the time it comes back to us more times than we think
