Mike's Transmission ULTIMATE VASCO C4
Am parting out a 66 Fairlane. I have a Mike's Transmission 'ULTIMATE VASCO C4 TRANSMISSION' that has a JW bellhousing that adapts to a FE. Can easily swap bellhousing to fit your setup. From Mike's site - - Top of the line C4 transmission built for extreme conditions. Each with the parts & technology it takes to survive with power adders such as nitrous or superchargers. Each transmission is specially modified for your application. This transmission features: ~ C4 transbrake valve body. ~ Vasco 26 spline input shaft. ~ Solid forward drum. ~ Six clutch pack in the forward & direct drums. ~ Six pinion front planetary. ~ Large diameter servos. ~ Rigid second gear band. ~ Teflon sealing rings. ~ Deep aluminum pan. ALSO includes 2 converters 8" 5K and a more streetable 10" 3K, a super trick Lokar transmission cable and a Turbo Action Cheetah SCS shifter. $4K Located in Hayward 94545. Shipping is not a problem.
guyoverfelt- Posts : 1
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» Ultimate 64
» Is this the ultimate SUV ??
» Converter Porn (Ultimate)
» ***** Ultimate Convertor Concepts *****
» Ultimate 64
