Mr gasket street scoop2 $275+shipping
This is a NEW never used. street scoop2 I have the single carb conversion piece as well. It comes with all the hardware besides 3 of the 4 bolts that go in from the bottom. everything else is their and If need be I will go buy the 3 bolts. this kit goes for $265 from jegs WITHOUT the single carb piece. (that is $75). And the plate to the far right is something I cut out If you want to use the shorter carb mount. (the plate is a filler). I'm in memphis, TN. paypal only pm for details.
bbfhnj- Posts : 13
» 16 gallon Jegs Pro-street fuel cell with mounting brackets $100+shipping
» Mercruiser Shim Head Gasket OK for Budget Street Use?
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» AN fittings for street street car (brakes)
» TFS Streets
» TFS Streets
