580ci a460 head & a 460 block
+32
Larry T
Mustang-junky
Tony M
larry552
butterbean
gmsmkr
70FB
460pulling
Dark Horse of Apocalypse
nastynotch600
J.Toney
ThndrChkn
nuclearcobra
kjett
bb429power
soupbean
norm
QtrWarrior
devildog
fordman50
tconnection
36 posters
Page 5 of 6
Page 5 of 6 • 1, 2, 3, 4, 5, 6
Re: 580ci a460 head & a 460 block
It's right at 4 inches from the carb.
tconnection- Posts : 866
Is there any special place or specs for mounting a fuel cell in the trunk of a fox drag car?
if you mount the cell in the hatch area you need to put a fire wall in front of it mount the cell dead center half in half hanging down if you got the room. then build the fire wall in front and let it go all the way up so it meets the hatch.... hope this makes sense reading it lol.
Edit: nice build by the way
gmsmkr- Posts : 1364
Ok thanks man. Would u happen to know what gauge material, sheet metal or aluminum to use and for closing in around the cell as well?
You can use as thin as you like just needs to cover the area and seal to the hatch when closed
There is an actual rule book spec for how thick the metal needs to be. I don't remember what it is now, but you should look it up before starting.
Jess
Jess
Mustang-junky- Posts : 438
Without looking in the book, I'd say .032 is spec.
maverick- BBF CONTRIBUTOR
maverick wrote:Without looking in the book, I'd say .032 is spec.
^^^^yup..I found it .032 for steel cover and .040 for aluminum ..... also if it is a plastic cell and you hang it out of the bottom as I stated before you need to cover the lower section that hangs down.
Thanks men, I'm right at ready for a test Pass. But dang, I got these 29.5s. on here and I really hate to trim, cut my fender bottom corners And mess my paint.
Thanks again.
Thanks again.
Bro it's a race car. You want it fast not pretty lol.
larry552- Posts : 335
Lol! Yea you are right.
Anybody got any pic of fuel pump location in the rear with fuel cell? Seems kinda tight under here.
I end up using .060 sheet metal cause the machine shop didn't have any .034.[img:16ae]https://i381.photobucket.com/albums[URL=https://s381.photobucket.com/user/tconnection/media/HPIM0774_zpsbcfodmqm.jpg.html]/oo259/tconnection/HPIM0770_zpsx4xeqd8w.jpg[/img:16ae][/url]
is that a fuel return line? on the other side looks like a roll over vent if so I would put a hose on it and run it out back.you don't need the fumes of the fuel in the car when theirs a fire...
Larry T- Posts : 1076
Larry T wrote:is that a fuel return line? on the other side looks like a roll over vent if so I would put a hose on it and run it out back.you don't need the fumes of the fuel in the car when theirs a fire...
^^^^^ this, and I recall you are only allowed a total of 12" of rubber in the fuel line, and you should use a bulkhead where the hoses pass through the floor.
FalconEh- Posts : 1448
I have a video of my car on this galexy s5 phone and don't know how to get it loaded on here. Do anybody know the steps or procedure? Or posting pics?
Take s5 to University Parkway & go past the cyper belt, (you won't need one, the one you have will last )
then LT ( left trun ) at the next galexy, LT again just before MW ( milkyway ) put medal to the pedal and you"ll land
square on 429-460.com
Have a safe trip
Have a safe trip
res0rli9- BBF CONTRIBUTOR
Any guesses on about what time my car should run giving everything work good and hook up? I'm figuring 950 to high 900 horsepower, 6c, 5500 converter, 430 gear, 29's, doubles in the front and rear. 3000 pound.
Mid to upper 8's
Well men, I finally made it to the track and tested the car. Just 2 peace of passes. Gotta get some seat time. Mainly was seeing if the engine was gonna make good power and the suspension go straight. I feel both did better than me. My second pass ever since I built the car was with Boosted GT and yea he skinned my ass.lol! Ofcourse I was half cocked but I'm gonna get right.
tconnection wrote:Well men, I finally made it to the track and tested the car. Just 2 peace of passes. Gotta get some seat time. Mainly was seeing if the engine was gonna make good power and the suspension go straight. I feel both did better than me. My second pass ever since I built the car was with Boosted GT and yea he skinned my ass.lol! Ofcourse I was half cocked but I'm gonna get right.
I was wondering if you were ever going to run it...Congratulations, how did it feel, what did it run.
Thanks! We'll I didn't really get a time. I figured I'ld practice on a pro tree and I left to early on the first pass and just on and off the pedal and the same on the second pass. I just dropped the transbrake sending it back to get checked out. It felt good. No butterflies and wasn't nervous. I only spinned it to bout 5500. I'm going to 7000 neXT time out.
I've been testing my car as well as getting some seat time. My last test Pass which was alike the rest, piece of a pass, I launched at 3000 and backed out with end the 60 and went back to it went to 2nd and it broke the tires. But anyway 60 was poor 1.55, 330 4.304 at 78mph. Et was 6.80 at 91mph. With this activity, 60 time and et, can a better et be guested if ran all out?
In the 10s. Probably mid to high 10. I needed a 6.4 in 1/8th and caught a high 9 @ 138
6jeff6- Posts : 279
» a460 head short block
» Motorsports A460 block and head blueprints
» meziere pump ,A460 head studs,new style A460 intake
» Cometic MLS head gaskets
» coolant leak between head and block at head bolt location.
Page 5 of 6
