580ci a460 head & a 460 block
+32
Larry T
Mustang-junky
Tony M
larry552
butterbean
gmsmkr
70FB
460pulling
Dark Horse of Apocalypse
nastynotch600
J.Toney
ThndrChkn
nuclearcobra
kjett
bb429power
soupbean
norm
QtrWarrior
devildog
fordman50
tconnection
36 posters
Page 3 of 6
Page 3 of 6 • 1, 2, 3, 4, 5, 6
tconnection- Posts : 866
Re: 580ci a460 head & a 460 block
I aint got this picture thing down pat. Once I get some brakes on this thing, I can drive it.
Nice...Get them brakes on!
FalconEh- Posts : 1448
Darn nice looking car there. Is she race only?
Dark Horse of Apocalypse- Posts : 171
Yea it is. A housing like this, would it have the big bearing ends? Im fixong to order some rear disk brakes.
tconnection wrote:Yea it is. A housing like this, would it have the big bearing ends? Im fixong to order some rear disk brakes.
Whith a housing like that they will build it any wany you want...Nice, The housing ends on the earlier picture has the Big Torino style ends with the more rectangular shape and with the triangles on the top and bottom...But the only way to know for sure is to measure it all the brake/axle manufactures should have the measurement chart for reference.
I need to ask a question about something that I don't know anything about.
The axle bearings for my M9, do they suppose to fit flush or do they suppose to protrude some/
Mine sticks out just a little I was told it was for keeping the bearing from walking in the housing my bearing is wider than the bearing cup on the housing by about 1/8''.
If you was running drum brakes the brake backing would take up some of the bearing that stick out I added a washer between the housing and thr retainer so mine only sticks out about a 1/16"
I got these disk brake brackets off of a 99 explorer and I need to know if a retainer has to be used with them. These brackets fit on the od of the bearing so I dont see how they suppose to hold the axles in.
Any help would be great.
tconnection wrote:I got these disk brake brackets off of a 99 explorer and I need to know if a retainer has to be used with them. These brackets fit on the od of the bearing so I dont see how they suppose to hold the axles in.
Yes the retainers has to be used
Finally got it all figured out and got everything.
Good.. Now show us some pic's.
res0rli9- BBF CONTRIBUTOR
tconnection wrote:[Once I get some brakes on this thing, I can drive it.
FalconEh wrote:Nice...Get them brakes on!
...and drive it
So far its looking good other than getting the rotors to work. I may have to buy new ones. I think they are 11.5 dia. Who would have some basics that has 5/8 stud holes?
Check with speedway motors for the rotors. I believe they have them.
460pulling- Posts : 249
pic
The anti roll bar wasn't really hard other than having to craw under over and between bars to weld but I got it done. I believe it'll hold.l
pic
Special wax make special things shine.
Looking good boss.
70FB- BBF CONTRIBUTOR
Thanks man. Once I run across some 31/2 inch weld pro stars and a 61/2 inch extended hood im gonna take a chill pill.
Thanks again
Thanks again
You going with the lexan mailbox?
Yea, im figuring on getting some 1/4'' lexan and build one. I think I can do it. I want it to where it will stay on the carb when the hood is removed. That will require building a bracket kit. Don't want to spend 250 for a setup. I can build a nice one for bout a 100 bucks.
» a460 head short block
» Motorsports A460 block and head blueprints
» meziere pump ,A460 head studs,new style A460 intake
» Cometic MLS head gaskets
» coolant leak between head and block at head bolt location.
Page 3 of 6
