2013 EMC Oakley / Freelander 572 Build
+9
quick 52
Dave C.
jeffgfg
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Here are the specifications on the Freelander Race Engines / Oakley Motorsports 2013 EMC entry. The engine ran flawlessly at the competition and pulled with no issues to the 7200 rpm upper limit on the dyno pulls.
Bottom End
Ford Racing A460 block with 4.600 bore
Scat 4.300 forged crank
Oliver 6.800 rods
Diamond dished pistons with coated skirts 11.4:1 compression
Innovators West damper
Moroso steel fox body swap pan and pick-up
Kaase oil pump
Top End
Fully ported Kaase P-51 heads
2.300 / 1.76 SS intake and exhaust valves
Fully ported TFS "Mafia" intake with 4150 aluminum adaptor
Quick Fuel custom 4150 carb 1000+ CFM
MSD 7 digital ignition and billet distributor
Valve Train
Comp billet roller cam 108 CL and .450ish lobe lift on the intake and exhaust
Morel .904 hydraulic roller lifters with bushed lifter bores
Manley 3/8 heavy wall pushrods
Manley Nex-Tech endurance springs with titanium retainers
Crower SS 1.8 rockers
Jomar stud girdles and poly locks
Ford Racing timing chain
Exhaust
2" Schoenfeld dyno headers with standard 3 1/2" collectors
5" Flow Master bullet race mufflers
Moroso evac system
Bottom End
Oliver 6.800 rods
Kaase oil pump
Top End
Valve Train
Exhaust
Moroso evac system
Re: 2013 EMC Oakley / Freelander 572 Build
Link to the Tuesday results from the competition
http://www.popularhotrodding.com/enginemasters/1309_2013_amsoil_engine_masters_challenge_tuesday_coverage/viewall.html
Here is a sample dyno pull from the competition. Pulls are made from 3000 to 7000 rpm.
TQ HP
3000 708 405
3100 706 417
3200 694 423
3300 678 426
3400 660 427
3500 640 427
3600 630 432
3700 636 448
3800 658 476
3900 687 510
4000 720 548
4100 749 585
4200 773 619
4300 793 649
4400 803 673
4500 809 693
4600 810 710
4700 813 727
4800 815 745
4900 814 760
5000 813 774
5100 808 785
5200 803 795
5300 795 802
5400 789 811
5500 785 822
5600 780 832
5700 775 842
5800 770 850
5900 763 857
6000 756 863
6100 745 865
6200 734 866
6300 723 867
6400 714 870
6500 700 866
6600 689 866
6700 677 864
6800 666 863
6900 654 859
7000 642 856
Avg 736 702
TQ HP
3000 708 405
3100 706 417
3200 694 423
3300 678 426
3400 660 427
3500 640 427
3600 630 432
3700 636 448
3800 658 476
3900 687 510
4000 720 548
4100 749 585
4200 773 619
4300 793 649
4400 803 673
4500 809 693
4600 810 710
4700 813 727
4800 815 745
4900 814 760
5000 813 774
5100 808 785
5200 803 795
5300 795 802
5400 789 811
5500 785 822
5600 780 832
5700 775 842
5800 770 850
5900 763 857
6000 756 863
6100 745 865
6200 734 866
6300 723 867
6400 714 870
6500 700 866
6600 689 866
6700 677 864
6800 666 863
6900 654 859
7000 642 856
Avg 736 702
A Pic of the team at the competition from left to right Jay Oakley, Curly, Phillip Oakley, Rob Orava and myself.
A pic of the torque monster and horsepower king awards and checks.
Dave,very nice build,great horsepower and torque numbers.Are you going to use it in one of your cars.
Later Mark.
Later Mark.
Mark Miller- Posts : 1888
Man 708 lb.ft. of torque at 3,000 rpm.That thing would be awesome in a heavy car or truck.
Later Mark.
Later Mark.
I'm going to put it in my 83 Mustang backhalfed car, With a 1.80 PG and some 4.30 gears.Mark Miller wrote:Dave,very nice build,great horsepower and torque numbers.Are you going to use it in one of your cars.
Later Mark.
That's awesome.
You keeping the juice roller in it?
Wondering why you bushed the lifter bores with those lifters?
How did they do with valve float or is it not an issue with these new morel race lifters? What about the dreaded valve train geometry issues?
windsor- Posts : 1167
Just awesome guys!! Congrats for a job well done!!!
jeffgfg- Posts : 338
What octane fuel were you using ?
John Myrick- BBF CONTRIBUTOR
Two checks. Same check number.... Nice build though. That shop looks pretty good too.
Dave C.- Posts : 1268
Dave C. wrote:Two checks. Same check number.... Nice build though. That shop looks pretty good too.
Those are just for pictures
That's the University of Northwest Ohio, Its a damn nice school for Vo-tech stuff.
Had to open the bores up anyway, the bushings are just a nice feature.windsor wrote:That's awesome.
Yes I intend to run the Girly Juice cam and see how it does. After tearing the motor down, I didn't notice any wear like previous EMC valve train stuff.
We where hitting 7200-7300 on the high side thru the pulls, no indication of float noticed. No indication of float on tear down either. And with the hp peaking at 6300-6400 not a whole lot of reason to pull it past 7000
very nice guys , thank you again for sharing the details
I'm super stoked about your results. I've always wanted to go HR since I had good luck with them in SBFs. These new lifters seem like the key since solid rollers can be hard pressed in my intended use. Drag Week running no more than 6500 in a 620 w/ small valve a460 heads.dfree383 wrote:Had to open the bores up anyway, the bushings are just a nice feature.windsor wrote:That's awesome.
Please keep us posted on your results as you run this engine further.
windsor wrote:I'm super stoked about your results. I've always wanted to go HR since I had good luck with them in SBFs. These new lifters seem like the key since solid rollers can be hard pressed in my intended use. Drag Week running no more than 6500 in a 620 w/ small valve a460 heads.dfree383 wrote:Had to open the bores up anyway, the bushings are just a nice feature.windsor wrote:That's awesome.
1] The lifters were/are important & they are some kind of fine...albeit expensive. I would not consider them to be "the key" but, an important piece of the puzzle.
2] In my opinion the main reason a typical hyd. roller package is easy on lifters is that 'they' have a VERY girly valve spring in the equation.
Daves springs are not 'girly' hence the happy at 7,300 rpm thing.
3] I do not have a dog or let alone a dog in the solid Vs. hyd. roller debate but, I do not want anyone to assume too much.
good mechanical roller stuff will last for drag week too.windsor wrote:I'm super stoked about your results. I've always wanted to go HR since I had good luck with them in SBFs. These new lifters seem like the key since solid rollers can be hard pressed in my intended use. Drag Week running no more than 6500 in a 620 w/ small valve a460 heads.dfree383 wrote:Had to open the bores up anyway, the bushings are just a nice feature.windsor wrote:That's awesome.
The springs are not girly..... But they aren't the big stud stuff used on the big drag race solid rollers either. I'm thinking a realistic 6500 rpm and good parts and a correct lobe a hyd roller should last just fine in a hot street build and provide some great power.Lem Evans wrote:windsor wrote:I'm super stoked about your results. I've always wanted to go HR since I had good luck with them in SBFs. These new lifters seem like the key since solid rollers can be hard pressed in my intended use. Drag Week running no more than 6500 in a 620 w/ small valve a460 heads.dfree383 wrote:Had to open the bores up anyway, the bushings are just a nice feature.windsor wrote:That's awesome.
"The springs are not girly..... But they aren't the big stud stuff used on the big drag race solid rollers either. I'm thinking a realistic 6500 rpm and good parts and a correct lobe a hyd roller should last just fine in a hot street build and provide some great power."
Why did I know I'd be sorry for posting in one of these chickenshit hyd. roller threads
In closing....wtf does "big stud stuff" mean?
Big double and tripple stuff those ones that are over 800# and alot of times over 1000#...... The "semi stud stuff" we have in this motor is leaning more towards something you can get away with in occasional street driver, But I still wouldn't want to use the stuff for a daily driver or something you'd expect to last forever.Lem Evans wrote: In closing....wtf does "big stud stuff" mean?
You better let us know how the Mustang runs with the 572 in it.dfree383 wrote:I'm going to put it in my 83 Mustang backhalfed car, With a 1.80 PG and some 4.30 gears.Mark Miller wrote:Dave,very nice build,great horsepower and torque numbers.Are you going to use it in one of your cars.
Later Mark.
Thanks Mark.
If I ever get a chance to run the freaking thing..... The way my work challenges are over the past couple years and the forseeable future.Mark Miller wrote:You better let us know how the Mustang runs with the 572 in it.dfree383 wrote:I'm going to put it in my 83 Mustang backhalfed car, With a 1.80 PG and some 4.30 gears.Mark Miller wrote:Dave,very nice build,great horsepower and torque numbers.Are you going to use it in one of your cars.
Later Mark.
Thanks Mark.
Great thread. Thanks for the insight gents.
Put it in the Mustang and schedule a week off for Sept. next year for Drag week
quick 52- Posts : 612
The cars not street legal..... I'm not sure I'd want to drive it (the car) that far any way..... 4 link, manual steering and brakes, no heater, no exhaust and a jungle gym can get miserable.quick 52 wrote:Put it in the Mustang and schedule a week off for Sept. next year for Drag week
But I would entertain some one wanting to put a car together with it and me riding along.
Page 1 of 2 • 1, 2
» EMC 2013 Oakley and Freelander
» Where's Freelander at?
» FREELANDER !!!!!!!!!!!!!!!!!!!!!!!!
» Hey Freelander
» Freelander....you know this guy?
» Hey Freelander
Page 1 of 2
