solid roller lifter recommendation
+8
CHARLIEB
kim
fordguy69
CDMBill
68galaxie
dirt_worker
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Re: solid roller lifter recommendation
This is a good topic :
I have anybody heard or used Comp Cams Sportsman Solid Roller Lifters 96838B-16. The ones I listed with part number come with Bronze bushing axle. Comp Cam offers two version of the Sportsman lifters in Bronze bushing or Needle Bearing Axle.
Right now I have the Comp Cams Endure-X Roller Lifters 836-16 but was thinking about sending them back for the Sportsman with Bronze bushing.
Any though or comment on these lifters?
CHARLIEB- Posts : 145
I haven't used those particular lifters so I can't comment on them. My reason for changing from the needle bearing lifters to bushing style was two different failure events one which may not have started at the lifter and one that definitely did, but the result was the same, needle bits all over the place, particularly on the upper side of the piston skirt whoch resulted in an over bore and new pistons each time.
Eventually stuff will break, and while I haven't lost a bushing lifter yet, my thinking is that even if it seizes or something similar it will do less damage than the needles.
The sound you hear is me knocking wood.
CDMBill- Posts : 182
I ordered the Crower bearingless lifters today...
Cheap insurance imo
Cheap insurance imo
dirt_worker- Posts : 535
CDMBill wrote:I haven't used those particular lifters so I can't comment on them. My reason for changing from the needle bearing lifters to bushing style was two different failure events one which may not have started at the lifter and one that definitely did, but the result was the same, needle bits all over the place, particularly on the upper side of the piston skirt whoch resulted in an over bore and new pistons each time.
Hello bill, I think I'm going to exchange the comp cams 836-16 for the ones that are a step above the ones I have listed. My builder said the ones I have now will work wirh the cam profile he will spec out and I will be able to drive it on the street and be durable. I 'm not going to take that chance and have needles everywhere in the motor. I'm going to spend the extra money to be on the safe side.
dirt_worker wrote: I ordered the Crower bearingless lifters today...
Cheap insurance imo
I hope your lifters serv you well with your build.
Wow..these bushed Crowers are nice!
Do yours have the groove from the oil band to the oil hole already? I had to put a small groove on mine and have seen some that were grooved from the factory.
norm- Posts : 257
Are all if these bushing-less lifters still $1000 plus? If I ever go back to a roller again this is my one and only choice. I'll never run a needle bearing solid lifter again.
tfsbbf466- Posts : 180
Yup...........but $1000 is cheap compared to the damage caused by a failed needle bearing.
Comp lifters on the left..crowers on the right.
Got to watch the bigger wheels they do change the cam specs.
And pushrod length may need to change toodfree383 wrote:Got to watch the bigger wheels they do change the cam specs.
schmitty- Posts : 4538
I didnt change wheel size.
.904's have a .810 wheel, .937's have an 8.50 IIRC. My engine builder didn't have BBF tooling for .937 so .904 was it. I would go the bigger size if I could have. Cam is spec'd for the .810"
Page 1 of 2 • 1, 2
» Need a roller lifter recommendation
» Need a roller lifter and rocker recommendation
» solid roller lifter
» Does a solid roller lifter with an O.D..903'' require bushing for a A460 block?
» Solid Roller Lifter Choices........
Page 1 of 2
