header primary size on a 496
crittersf1
72mav
Re: header primary size on a 496
rmcomprandy wrote:bbf-falcon wrote:That ain't no big cam..... and shifting at 7200 is about right for an engine peaking at 6700....
Now i know why you race dyno's instead of cars.
A step header with 2" to 2 1/8" primary tubes 31 inches long with a 3 1/2" diameter collector 17 inches long is the correct size for a 496 engine at 7,000 RPM ... on a dyno OR a drag race car.
USE a 2" straight tube header primary if the RPM level EVER drops below 5,000 RPM.
And that's what I learned from all the dyno time......
When's the last time your car was on the track Rick?
One thing I learned in 40yrs of racing is that just because my engine will rev to 8k, that's no reason to shift it there . and a dyno is not a racecar.
» header primary size
» Trying to find correct header primary size
» Header primary size - 547 A460 engine
» 6115 slip in header primary tube needed
» super comp headers primary size question rpm hp limits
