chassis set up ??? mud truck weight distribution ??
crittersf1
460bronco
lghting94
kjett
racinghabbit
Page 2 of 2
Page 2 of 2 • 1, 2
Re: chassis set up ??? mud truck weight distribution ??
1978 ford bronco, no top or tailgate. 4840 pounds
460bronco- Posts : 364
80 f150. Iron heads c6 208. 35" Boggers. Bench seat. No gutting at all. 3822. Will be a little lighter this year.
FORDMUD- Posts : 290
kjett what does your truck weigh?
racinghabbit- Posts : 575
28and change on the cuts. But there really isn't much left in the truck.
kjett- Posts : 1169
when adding weight where are you putting it? In the frame rails? over the rear axle ? all the way at the rear?
kjett wrote:Over the winter, my ranger will go away and I'll be coming back out with a much lighter f-150 that is more set up to handle mild hill and hole tracks as well as flat tracks. Long story short, back to the drawing board on setting up weight bias....
Karl what year F-150 are you going with?
68formalGT- Posts : 864
Wherever it needs it! You need to scale the truck to see.racinghabbit wrote:when adding weight where are you putting it? In the frame rails? over the rear axle ? all the way at the rear?
68formalGT wrote:kjett wrote:Over the winter, my ranger will go away and I'll be coming back out with a much lighter f-150 that is more set up to handle mild hill and hole tracks as well as flat tracks. Long story short, back to the drawing board on setting up weight bias....
Mid 90's
kjett- Posts : 1169
Thanks Everyone!!!
Made some weights over the weekend.....They weigh between 69 and 88 labs...
Yes them Ford Powered weights will make it faster
res0rli9- BBF CONTRIBUTOR
after a ton of work... the best i can get my ranger chassis 58% front and 42% rear... front left 1215 lbs , front right 1258 lbs, rear left 888 lbs, rear right 847 lbs, left weight 2104 , right weighs 2104.. so i am perfect 50% left and right...i did start out at 67 % front and 33% rear in the begining...
Any other idea's??
Any other idea's??
Page 2 of 2 • 1, 2
» Weight Distribution and Wheel Base
» truck weight
» When ordering a converter how much does the truck weight affect it.?
» Updated pics of the truck from the chassis shop
» Intake distribution
» truck weight
Page 2 of 2
