are these valve cutouts right?
pkerot
http://www.ebay.com/itm/151062631141?_trksid=p2060778.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Shouldnt the valve pockets in these pistons both be on the same side?
pkerot- Posts : 14
Re: are these valve cutouts right?
They are correct and typical of inexpensive pistons with 2 reliefs
Just a note those are hyperujunktics
the Coug- Posts : 3055
pkerot wrote:http://www.ebay.com/itm/151062631141?_trksid=p2060778.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Pistons with two opposed intake valve notches have an "OFFSET PIN" so, they can be used on either side of the engine and the offset will still be in the correct direction.
I always heard them called hyperpathetics.the Coug wrote:Just a note those are hyperujunktics
4thHorseman- Posts : 400
thanks, which pistons do you recommend?
pkerot- Posts : 14
pkerot wrote:thanks, which pistons do you recommend?
It is not as simple as that ... different pistons for different builds.
rmcomprandy wrote:pkerot wrote:thanks, which pistons do you recommend?
What Randy means is....What are you building and how do you plan to use it?
maverick- BBF CONTRIBUTOR
» cutouts
» Exhaust cutouts?
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» valve cover studs for aluminum valve covers
» How do you check valve to valve clearance????
» Exhaust cutouts?
