Compression help !
Compression help !
I Have 1986 460 out of a motor home stock bore, crank, rods and pistons, I pulled the d3ve heads off and put c8ve-e heads on. The heads have cobra jet size valves 2.250 intake 1.760 exhaust , they been milled 0.10 thousandths I put stock fel-pro head gaskets on I think there 41 thousands compressed . Just kind of wondering around what my compression might be?
Thanks for any help!!!
ctdck- Posts : 49
Re: Compression help !
ctdck wrote:I Have 1986 460 out of a motor home stock bore, crank, rods and pistons, I pulled the d3ve heads off and put c8ve-e heads on. The heads have cobra jet size valves 2.250 intake 1.760 exhaust , they been milled 0.10 thousandths I put stock fel-pro head gaskets on I think there 41 thousands compressed . Just kind of wondering around what my compression might be?
Probably around 8 to 1.
rmcomprandy wrote:ctdck wrote:I Have 1986 460 out of a motor home stock bore, crank, rods and pistons, I pulled the d3ve heads off and put c8ve-e heads on. The heads have cobra jet size valves 2.250 intake 1.760 exhaust , they been milled 0.10 thousandths I put stock fel-pro head gaskets on I think there 41 thousands compressed . Just kind of wondering around what my compression might be?
Wouldn't have been around 8 to 1 with the D3VE Heads?
Mark Miller- Posts : 1895
In the 9-9.5 range depending on head actual CC.
Bet on closer to 9
Bet on closer to 9
I misread -- I was reading D8VE heads like some marine engines had.
"86 motorhome short block = 22 cc oblong dish pistons about .040" down the bore; (about 10 cc).
11.5 cc head gasket
about 76 cc combustion chamber head
942 cc cylinder
The math says about 8.9/1 ...
11.5 cc head gasket
942 cc cylinder
Thank you
Thanks all of you for the help
ctdck- Posts : 49
» Can you raise compression by changing rod length with same compression height?
» Cam/Compression help on 472
» 545 compression
» compression ?
» how can i tell the compression
» 545 compression
» compression ?
