Building a c-4 for a 408
whitefield
Gregaust
manofmerc
Friend has a 65 mustang we are installing a 408 Windsor .We plan on a c4 for the transmission .What do I need to look for ? Case fill or pan fill ?I see that Broader has a clutch drum that holds 5 clutches is that a need? how about the #9 roller bearing are the benefits similar to a c-6 and since a c-4 has two bands what material for the bands and are the factory servos adequate.This will be a street strip car the engine has a hyd. roller 10.0 compression brodix heads edelbrock air gap dual plane intake .Just needing a direction and how does a c-5 compare
manofmerc- BBF CONTRIBUTOR
Re: Building a c-4 for a 408
If you're anywhere near Alabama I have a family friend who is really good with C-4's. He and my dad both used them with big blocks for years with no problems. For high HP engines he recommends the pan fill, says they're a little thicker case if I remember right. At one time he had one with fabricated bell housing for an 455 ci FE he ran for a lot of years, then moved on to the 385 stuff. he's had them behind 532, 598, 600+ ci.
way more info than you asked for I know but what I was getting at is At that HP level on a small block Any case would probably do the job if it's built right. He's a machinist by trade so he does all the machining to add the extra clutches and what-nots himself. Let me know if you're interested I'll give you his number, You won't find a nicer guy to deal with either.
stanger68- Posts : 489
You could always PM jon/richter69 here, he built & abused C-4's in his Mustang for a long time before going 'glide.
DILLIGASDAVE- Posts : 2262
I prefer the pan fill but we have plenty of them here ..
A case fill will do you ok .
5 clutches in top gear is a great idea , easily done if you wanted to do yourself.
Will need a good planet set also, most originals now are just plain worn out
Roller bearings definitely are a nice addition. If you can machine can show you how
The C4 #9 roler is good but also an added lube feed also works well
Gregaust- Posts : 619
pan fill versus case fill
Is there a difference between the bell housings on a pan fill ? Will headers for a 65 mustang clear a pan fill bell housing ? Somehow I believe a truck c4s bellhousing is larger and isn't a pan fill c4 from a pickup truck ?Don't much c4 clutch packs come with just 3-4 clutchs ?I am in Ga. so Ala. is right next door .Thanks for everyones help .Doug
manofmerc wrote:Is there a difference between the bell housings on a pan fill ? Will headers for a 65 mustang clear a pan fill bell housing ? Somehow I believe a truck c4s bellhousing is larger and isn't a pan fill c4 from a pickup truck ?Don't much c4 clutch packs come with just 3-4 clutchs ?I am in Ga. so Ala. is right next door .Thanks for everyones help .Doug
Case fill with a 157 tooth flywheel will be your better choice . Pan fill will be 164 tooth flywheel and a little more combersom in the 65 mustang with long tube headers. Just my 2 cents
whitefield- Posts : 2243
PAN FILL
I've seen small bell pan fills. The tube gets in the way of headers more. Case fill is fine and is easier to find with small bell. I always had to cut on side of bell to use the big size bell (164) with long tube headers. Done a couple 66 mustangs with the bigger bell, much better like said with 157.
ED468- Posts : 199
ED468 wrote:I've seen small bell pan fills.
Really ??? Not seen them
c-4
Good to know that I really need a case fill for my friends car .I went to my local junk yard Saturday the only c-4 I found was in a pickup and it was a pan fill.So we are still looking around .A little info on this car it was his wifes car 65 with pony interior six cylinder.It is becoming his daughters car with a little drag strip time involved .We installed a AJE front suspension this past week looks really good ! After we cut back and welded in plates for the shock towers I measured 27" between them!With some work on that fire wall I think a big block would fit .Thanks for the info a case fill and 157 tooth flywheel is what we are looking for .Doug
Are the bellhousings interchangeable from the pan fill to the case fill? Excluding, of course, the big bell C-4.
pmrphil- Posts : 170
pmrphil wrote:Are the bellhousings interchangeable from the pan fill to the case fill? Excluding, of course, the big bell C-4.
IIRC no the pan fill C-4's have separate bolts to bolt bellhousing to trans case,the case fill C-4's the front pump bolts are used to bolt bellhousing to trans case!!!
Mark Miller- Posts : 1888
You can use the small bellhousing on the pan fill c4's since they bolt to the pump, but you can't do the opposite because the pan fill uses an external flange for the large 164 tooth bellhousing to bolt to.
1982GT- Posts : 113
Mark Miller wrote:pmrphil wrote:Are the bellhousings interchangeable from the pan fill to the case fill? Excluding, of course, the big bell C-4.
1982GT wrote:pmrphil wrote:Are the bellhousings interchangeable from the pan fill to the case fill? Excluding, of course, the big bell C-4.
Both of these statements are true and if you bolt the case fill bell to the pan fill case you will have to do a lot of measurements to get the correct torque converter. The pan fill case Is some what larger were the bell housing attaches. . Case fill is your best bet . Good luck
» Building help.
» HELP IN BUILDING A 545
» building c6 4x4
» Building my first C6
» Building a ´71 SCJ now.
» building c6 4x4
