Parts selection for blown application (Budget - Mild Boost)
+8
cstmwgn
Uglytruck
quarterflash
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
I’m going cross eyed searching the internet trying to fill in the blanks “TBD” on this project. The parts in bold have already been acquired. Pistons are my biggest frustration. Haven’t even considered cam choice yet and rods seem easy after pistons are selected. Your input would be greatly appreciated!
Block: D9TE-AB (two available - .060 over or std) Wanted D0VE block but tired of looking locally
Crank: Eagle CRS446041402200 4340 Forged Crank 4.140 Stroke
Rods: GRP Alumimum 6.7
Heads: M-6049-SCJ
Pistons: TBD (Diamond > Budget) Outstanding website though
Cam: TBD
Manifold: BM-5056 429-460 FORD UNPOLISHED BDS INTAKE SATIN
Blower: 6-71 (I know its small but "Budget - Mild Boost")
Injection: Enderle Bird Catcher Fuel will be high octane Gas
This engine will be an upgraded for 1978 Cole Hydro "Quarter Flash".
Thanks in advance for your help.
Steve
Heads: M-6049-SCJ
Cam: TBD
Steve
Last edited by quarterflash on December 23rd 2020, 10:55 pm; edited 3 times in total (Reason for editing : Got Rods)
Re: Parts selection for blown application (Budget - Mild Boost)
quarterflash wrote:I’m going cross eyed searching the internet trying to fill in the blanks “TBD” on this project. The parts in bold have already been acquired. Pistons are my biggest frustration. Haven’t even considered cam choice yet and rods seem easy after pistons are selected. Your input would be greatly appreciated!
Rods: TBD
Heads: M-6049-SCJ
Cam: TBD
Steve
What fuel is to be the intended use ...?
That alone makes a lot of your decisions.
Fuel Type
I had problems with this post initially and ended up with duplicates. Some where along the way the stated fuel type got lost
Fuel: Gas
Thanks,
Steve
Fuel: Gas
Thanks,
Steve
what octane rating you going to use 87, 89, 91, or 93 I see you in Florida so you should be able to get 93 I know we have 93 here in south Georgia
As I see it, the problem is going blown gas with an Enderle Bird Catcher. If this is the tradtional mechanical system you may find it tough to get the tuneup right resulting in broken/burned up parts along the way. The usual choice for that kind of deal is methanol as it is easier to tune and gentler on parts.
Uglytruck- Posts : 44
Fuel Type
The idea of having to purge the fuel system after use seems like a major PIA. I was hoping to stay on the rich side of the tune with gas and avoid problems. Do you feel it would be difficult to do.
Steve
Steve
110 race fuel
69F100 wrote:what octane rating you going to use 87, 89, 91, or 93 I see you in Florida so you should be able to get 93 I know we have 93 here in south Georgia
We have 93 non-ethanol available locally but could run on 110 race fuel if needed. Quality fuel is cheaper than parts/labor, plus run time is very short.
Steve
I don't purge my system until I put it to bed at the end of the season. When I buy a drum of methanol I put in a bottle of top lube like Klotz Uplon or products like it. As a result, I never have the dreaded white fuzz. At the end of the season I drain the fuel out of my tank and put in a gallon or so of regular gas and fire it up and let it run fat. Then purge the remaining circuits. I apologize for throwing this in without actually trying to answer your original question, but fuel type affects what compression ratio to use ect....
cool40 likes this post
I never purge mine. I leave fuel in it all winter and the pump doesn’t dry out and leak like it will if I drain it. Clean the injectors and fire it up in the spring.
methanol for fuel
I have been reading about mechanical fuel injection and methanol. The book I got is "Fuel Injection Racing Secrets - 2nd Edition" written by Bob Szabo. It's clear to me that he feels methanol is the only way to go. My hat is currently setup for it but I did purchase a blown gas barrel valve for it. I got turned off when he started talking about how corrosive it was. Maybe I took the section onf that too seriously. Just couldn't see purging after each outing then dealing with getting the system primed again.
Steve
Steve
It’s definitely not as user friendly as gas and is pretty corrosive. It’s easy to contaminate your oil if it’s not adjusted right or not warmed up good when you do run it. One of the best tips I got from a member on here was to not start it up just to hear it run lol. It’s pretty important to heat it up to 180 or more to burn the moisture out of the oil and use that shut off valve to lean it out and build heat at idle.
fill in the blanks for a methanol build
Since the conversation here has developed a methanol twist and it sounds more practical, How would the contributors so far fill in the blanks "TBD" for a methanol build. If the gas guys come along later then we'll have that discussion as well.
Thanks,
Steve
Thanks,
Steve
Looks like it's for a boat. But is it a race boat?
stanger68- Posts : 489
quarterflash wrote:Since the conversation here has developed a methanol twist and it sounds more practical, How would the contributors so far fill in the blanks "TBD" for a methanol build. If the gas guys come along later then we'll have that discussion as well.
Thanks,
Steve
I run a Ron's 1800 cfm tolit I have a gas primer I fire mine up on I can get mine up to 180* on a quart of pump gas and methanol likes compression so keep that in mind if you decide on running Methanol. My 460 I ran it on methanol with 10.5 compression with a methanol carb. I went to a 552 with 14.5 compression it will fire up easier on 14.5 than the it did on 10.5 with carb. You will burn a little more Methanol then you will on gas so you will not go as far on a tank
Methanol starting to sound better to me
I like the idea of higher compression. It seems like you're a cam change away from un-blown gas if you decide to bail on Methanol. I got a good deal on GRP 6.7 rods now my available options are shrinking even more.
What about gas and a pair of carbs?
Cheap, easy to tune and it works very well in mild setups
Carbs on gas
dfree383 wrote:What about gas and a pair of carbs?
This was the original plan. I bought a pair of QuickFuel 750's and planned to do the Boost Reference modification on them. I ended up getting a reasonable deal on the Birdcatcher so the plan evolved despite others suggesting the hat was more suited for Methonal. I have the QuickFuel 750's on the boat now but still have the original Holley 750's rebuilt and on the shelf. This evolving thought "attention deficit disorder" is documented on my website"dragboatfever.com". The cost of custom pistons is my current hangup. Seems like two sets would be in order 8:1 for gas and 12:1 for Methanol. Then what bore size to allow for future flexibility. As far a Compression ratio is concerned 12:1 would at least allow for blown Methanol and un-blown gas, 8:1 sounds like blown gas only. I'll get thru this but I'm getting a headache.
Steve
The 6-71 would be much better on a shock stroke BBF making 8:1 pistons pretty cheap
dfree383 wrote:The 6-71 would be much better on a shock stroke BBF making 8:1 pistons pretty cheap
That's where my thoughts began but I wanted a forged crank and none are available 3.85 stroke. I'm starting to think it's a conspiracy.
Steve
quarterflash wrote:dfree383 wrote:The 6-71 would be much better on a shock stroke BBF making 8:1 pistons pretty cheap
Steve
If you can get a 429 heavy truck crank, they are forged at 3.590" stroke which can be modified and offset ground to a 3.87" stroke with a 2.200" rod journal size.
There were probably hundreds done over the tears for those out there who wanted a forged crank with a shorter stroke...
I have a D0VE-A block - stock bore in Palmetto with a sonic check - what is it worth to you?
cstmwgn- Posts : 5
cstmwgn wrote:I have a D0VE-A block - stock bore in Palmetto with a sonic check - what is it worth to you?
$350 if it has no issues.
Steve
Quarterflash, check your messages.
JBR-3- Posts : 266
Mechanical Injection
I have a set of 4 port upright Hilborn injectors running gasoline on my lake boat and they work well. I don't know much about the Enderle injectors but have heard they aren't as easy to get the fuel curve good for cruising like the Hilborns.
GD
Video https://youtu.be/ne_PAhb43Qc
GD
HPbyGD- Posts : 6
HPbyGD wrote:I have a set of 4 port upright Hilborn injectors running gasoline on my lake boat and they work well. I don't know much about the Enderle injectors but have heard they aren't as easy to get the fuel curve good for cruising like the Hilborns.
GD
I don't think the jackets are rated for 107mph but I'd do it anyway. Love the LOPE.
Thanks for sharing.
Steve
Page 1 of 2 • 1, 2
» Pistons, rods, cam for low RPM mild boost
» Boost vs Cubes vs The Budget
» Budget parts for my 460 build
» Budget Build with bolt on parts
» Budget Street/Strip Stroker Build Advice w/ Existing Parts plus???
Page 1 of 2
