429 Cam failure
429 Cam failure
Hello, new to this and new owner of BBF Cobra jet with Cam and lifter failure. Not sure if motor was put together correctly or Chinese parts were the reason, both lobes on #1 and wear on bearings.
70 Cobra- Posts : 4
Re: 429 Cam failure
70 Cobra wrote:Hello, new to this and new owner of BBF Cobra jet with Cam and lifter failure. Not sure if motor was put together correctly or Chinese parts were the reason, both lobes on #1 and wear on bearings.
I would post this in the Engine Tech Section if you're looking for answers!!
Mark Miller- Posts : 1894
Re: 429 Cam failure
Most likely not a part failure. More likely that modern low zinc oil is to blame. Modern oils are not compatible with flat tappet cams. You have to use additives or an oil like joe Gibbs or Lucas that has high zinc contents.
stanger68- Posts : 489
Re: 429 Cam failure
ZDDP additives don't work for break in and in general are a waste of money. There are modern oils with plenty of zinc for flat tappets and specialty oils made just for flat tapper engines like the Driven HR oil. If you think you need an additive for your oil these days with all the specialty oils on the market, you're using the wrong oil.stanger68 wrote:Most likely not a part failure. More likely that modern low zinc oil is to blame. Modern oils are not compatible with flat tappet cams. You have to use additives or an oil like joe Gibbs or Lucas that has high zinc contents.
Scott Foxwell- Posts : 419
The Mad Porter and Mark Miller like this post
» Name that failure.....
» 429 Rod Failure: Why is it ALWAYS #6
» Cam failure
» 460 bearings failure
» Cam bearing failure
» Cam failure
