Torrington bearing on the park gear
While researching stuff related to my recent pump failure, I came across a video that recommended installing a torrington on the park gear (https://www.ckperformance.com/View/ROLLERIZED-PARK-GEAR). I hadn't heard of this upgrade before and am wondering if there is a benefit to it for drag racing?
Here is the video and you can skip to 6:24 where he talks about this. https://www.youtube.com/watch?v=pR1BzCjoPCQ&t=647s
Re: Torrington bearing on the park gear
That's the number #10 Thrust washer. It's the one I meant, not #9, when I mentioned the sprag race drilling through oiling hole, mod. I have spun one of the washers that was not staked well enough.
It does take some load from the output shaft. I don't see why you would not rollerize it.
supervel45- Posts : 4454
Some I do some I leave . The washers don't usually wear much anyway . It's the usual T350 bearing
Gregaust- Posts : 620
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» Torrington bearing to control crank thrust
» how do you guys get the bearing off the pinion gear
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
