pic's of your vacumn pump
Guy's I don't have alot of room to mount a Vacumn pump w/my Alt. Can you post some pic'c of yours mounted w/engine plate. And if you have one For Sale let me know.
Re: pic's of your vacumn pump
how bout some pics of your setup and the room you have to work with?
you have more room than you think- just take some time and find a place - i picked up 2.5 tenths when i added mine -ive got a alt-crank trigger and fuel pump -
hope this helps
hope this helps
Has anyone tried one of those electric vacuum pumps that MPG has listed on there site??
Thanks Tore
Thanks Tore
Tore- Posts : 862
Thanks for the pic's Gerry.
Tore, I was wondering about a electric deal myself. I have a couple of friends that run them w/no issues.
Does anyone else have any experience with an electric vacuum pump? How much pressure do they draw?
Tore
Tore
Tore- Posts : 862
I run an electric pump on my dragster.
IMHO, don't count on an electric pump to make any more power. At idle it will pull 5-6" max that's more than a set of header evacs, but I don't know about WOT.
The electric pumps works great on an alcohol engine to keep the condensation out of the oil. That's why I use one. The oil still looks new after 75+ passes instead of the milkshake looking oil you see on many alky engines. I run my pump any time the engine is running and I also run it 2-3 minutes after a pass and it keeps all the water/alky vapor sucked out of the engine.
That is you Rick, and you don't have to worry about room.
342g- BBF CONTRIBUTOR
» Looking for pics of engine plate with power steering pump
» Fuel pump in trunk? A2000 opinions and pics needed
» Vacumn pumps
» vacumn cam suggestions
» 460 timing without vacumn advance!
» Vacumn pumps
