Guys with Foxbody BBF!!!
+6
Big block fox 339
quick89
1Bad91
10 posters
Hey guys and gals, I'd like to know what your BBF runs in temperature wise in your foxbody??? Tell me what cooling componets your using and T-stats used or not and what degree your using if you are. Thanks
1Bad91- Posts : 267
BB cooling
flex-fan, electric fan on switch, 1/2 inch restrictor instead of thermostat, car runs max 180
quick89- Posts : 10
Re: Guys with Foxbody BBF!!!
quick89 wrote:flex-fan, electric fan on switch, 1/2 inch restrictor instead of thermostat, car runs max 180
what size fan and how many you running?
1Bad91- Posts : 267
no fan, no radiator, in fact I use oil pan and block heaters between rounds.............have a gas primerplus system now so I can generate some heat in the lanes when I have to wait on an oil down.
richter69 wrote:no fan, no radiator, in fact I use oil pan and block heaters between rounds.............have a gas primerplus system now so I can generate some heat in the lanes when I have to wait on an oil down.
i think your the happiest guy on this forum......you must have no bills...lol
1Bad91- Posts : 267
no car payment, no tool payment, no credit card debt, hell just a mortgage and utilities.................
Pretty happy I rekon lol.
good for you brother.....I wish I could say that
1Bad91- Posts : 267
Its been a lot of work.............my wife has a retirement fund, mine sits in the shop lol.
richter69 wrote:Its been a lot of work.............my wife has a retirement fund, mine sits in the shop lol.
im too young for a retirement fund...lol
1Bad91- Posts : 267
but I really do need some help cooling this motor......shoot this motor got around 230 after my final pass winning the zmax pinks all out...something just aint jiving here. I have twin fans with shrout and everything else that needs to be in place, car runs not so hot down the track....it's when I'm iding back she gets up in temp
1Bad91- Posts : 267
Im running a csr elec pump a griffin radiator an electric fan cant remember size and no t stat i cant get it over 190 it can idle for hours
Big block fox 339- Posts : 279
Tune? Airflow? Hoses colapsing? High pressure cap? Clean system? High enough water pump volumn?
dfree383 wrote:Tune? Airflow? Hoses colapsing? High pressure cap? Clean system? High enough water pump volumn?
Motor sits at 34 degrees timing, tune is pretty much dead nuts, all steel braided lines, 16an on top, 20an on bottom, brand new motor, mezier water pump which I bought from Lem, griffin radiator, twin 10 inch fans with custom shrout........I do know the feed hose running to the housing runs a little up hill, will this cause any problems??
1Bad91- Posts : 267
1bad91, How much compression are you running? Running that hot after 3 hot laps would be considered normal IMO.
compression is 9:8:1.....pump gas motor
1Bad91- Posts : 267
I kind of agree with Rick if 230 degrees was after 3 hot laps.I wander if you could fit 2 electric fans that are a little bigger.I have a 89 Mustang with a 466 BBF Flat top pistons and Ford Racing Aluminum Cj heads.I have a Autozone waterpump,180 degree thermostat and a Howe 19"X31" radiator with a 15" water pump driven fan and a 5.0 Mustang fan shroud.If i'm cruising along about 55 mph it will stay at about 180 to 190 degrees depending on outside temp.If i'm putting along under 35 mph the temp will creep up to about 200 then i turn my electric fan on.I think on the Fox Body 87-93 cars the big problem is they just don't get enough air through the front of the car at low speeds IMO.
Later Mark.
Later Mark.
Mark Miller- Posts : 1895
I agree with the air not being enough in this car, I looked a little closer and realized they really dont get much air.
1Bad91- Posts : 267
Foxbody BBF
One 15 inch electric fan, tried just the electric with the flexilite fan removed, no go needs the fleilite more than the electric even without running a fan shroud
quick89- Posts : 10
quick89, say that again....im trying to figure out what you said
1Bad91- Posts : 267
I have a Weiand mechanical water pump (slighthly overdriven), 160* thermostat, Be Cool radiator, Be Cool (Spal) dual 11" fans with integral shroud and it will idle for long periods of time and maintain 190*. The engine is also lowered 1.5", which puts the intake below the level of the radiator.
Gary
Gary
GTmustang- BBF CONTRIBUTOR
1bad91:
I don't know if this helps you any, but of the 2 Fox body 460 T-Birds we run, my '87 Turbo Coupe uses a 17 inch flexfan and the shroud from a 86-93 5.0 Stang. (pics below) That car has no grill and has to pull the air thru the radiator from below the bumper. Runs great @ 185 with a 9.0 to 1 CR 460.
Disregard the following if I looked over it in one of the previos posts, but you need to have a 1/8th inch steam hole in your thermostat to help "burp" any trapped air in the block.
83-88T-Bird Guy- Posts : 1003
i have an 88 mustang with an 11.8 to 1 514. my cooling system consist of a 31" aluminum rad from summit a mr gasket water pump drive motor turning a aluminum water pump and some electric fans from a ls1 camaro. the temperture stays between 180 and 195 all day in the florida heat riding along or sitting.
hayhauler- BBF CONTRIBUTOR
BBF Mustang
Sorry, senior moment, car would overheat with just thw 15 inch electric fan, running a flexilite fan on the crank pulley without shroud solved the problem. I don't even use the electric, only if it goes above 180.
quick89- Posts : 10
» what oil pan do you guys have in your 460 foxbody?
» New guy with a BBF and a foxbody!!
» complete 9 inch for foxbody
» BBf foxbody oil pan
» 429 in foxbody
» 429 in foxbody
