15,000 to win FTI Extreme !!!
come get you some guys !!!!!
15,000.00 to win !!!!!
at the Oct 22,23,24 ORTC event !!!
Re: 15,000 to win FTI Extreme !!!
FTI X-TREME STREET TECH CARD $150.00
OCT 22,23,24th @ SGMP
n/a SB 2500lbs
n/a BB short deck conventional head 2900lbs
n/a BB tall deck conventional head 3000lbs
n/a BB short deck big chief 3000lbs
n/a BB 10.2 tall deck big chief 3150lbs
28 X 10.5 nonW slick or 275 drag radial
Nitrous Small Block: 2600 lbs
Nitrous Big Block (10.2 deck okay, No 5 inch bore space): 3200 lbs add 150 lbs for Big Chief
Add 50 lbs on all nitrous combos w/non stock suspension, must have stock frame rail
Big Chief combos max 3 kits
supercharged (SB only)- 3100lbs base weight with F1C or Ysi
add 100lbs for F1R/Xi or
add 150lbs for Z trim or =
add 200lbs for F2
add 50lbs for non inline head
deduct 50 lbs for non intercooled
add 50lbs for non stock suspension; must have stock frame rail notch okay
gear drive okay
single turbo (SB only)- 3100lbs base weight with 80 mm
add 100lbs for bigger than 80 mm
add 150lbs for 88 mm
add 200lbs for 94 mm
add 100lbs for non inline head
deduct 50lbs for non intercooled
add 50lbs for non stock suspension, must have stock frame rail - notch okay
twin turbo's (SB only)- 3300lbs base weight max 67 mm
add 50 lbs 70 mm
add 150lbs 76 mm
add 200 lbs 80 mm (must run on 275)
add 100lbs for non stock suspension, must have stock frame rail notch okay
Leaf springs - 100#
No wheelie bars
Mufflers required on non turbo charged entries
Progressives okay
7531 okay
Lexan okay
Fiberglass okay
Alcohol -Ok
Auto Trans or Factory clutch type manual (clutch assisted okay)
REDUCERS -OK
damn thats a payout !!!
605FOX- BBF CONTRIBUTOR
ck for updated rules
www.dragraceplace.com
looks like the sb nos guys are going to add some weight
bunch of crybabies over on the bullet .......... and these guys are supposed to be at the top of there game ...come on
I look at like this if you have a bunch of guys complaining about the rules (w/ diff combos) to me it tells me the rules are really close , just stfu and run what you brung !!!!!
shoot i cant wait ... i will have the slowest car out there !!!!! but it will still be fun to line up with the big dogs ....... atleast 1 round
» pro extreme
» Extreme Newbi Needs help
» Extreme stroker kit.....
» VAVLE HEIGHT SETUP RANGE FOPR OEM dove 429 HEADS
» Comp Cams Extreme Energy 270 4X4 Cam
