Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
+40
Rich Osmond
J.Toney
CDMBill
Straubtech
521swbford
glenevans
gmsmkr
Dark Horse of Apocalypse
tfsbbf466
Dave C.
Price5113
CHARLIEB
bb429power
bigjohn2007
droppedf100
valleydawg
njstang87
61coon
norm
56Tbird
Dave Maxwell
ThndrChkn
Barney
dirt_worker
44 posters
Page 2 of 6
Page 2 of 6 • 1, 2, 3, 4, 5, 6
Re: Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
aint no magic parts in um, yes Ive built a few lol.
I don't care who you go with i just stated what I have and it works good. That is the only thing done to an all original 360,000 mile Trans. I even dumped the old fluid back in lol. Now hopefully it can take a 100 shot lol
droppedf100- Posts : 173
windsor- Posts : 1167
Engine is back in the shop getting some head/manifold work and a custom cam and an oilpan upgrade. Were shooting for 1000 hp on pumpgas.
dirt_worker- Posts : 535
That would be badass 4 digit hp n/a on pump gas. Can't wait til it's done and in the truck again.
Well I hope you keep us updated with your rebuild, I would like to know because I am building a 598 pump gas motor. I am looking to shoot for 1000 hp as well. I have everything except the heads,pistons, cam and push rods. I am looking to run pump gas, it will be mostly street for use and very little track time. The only reason is because we dont have a track here the nearest track is 2 hours away.I also like that fact that 1000 hp on street will be so cool! Please keep me post it on you out come. I was thinking of the trick flow heads the 360cc but I know if they will be too big for the street. I am also using kooks 2-1/4 headers in my for my foxbody I dont think they make anything bigger to fit.
Well it was good hearing from you and please keep me post it on updates.
Thank You. Charlie
Thank You. Charlie
CHARLIEB- Posts : 145
Here is a crappy photo of what the f100 front end looks like now. Its mostly mustang aftermarket components. Has dual piston 2002 mustang 5 lug brakes.
What kinda stall you gonna run since it'll be on the street?
Its a custom Continental...and its big. I also run a t-brake too
Update....
After purchasing an awesome motor and mid plate from Keith Fulp I finally made some real progress on the ford.....(I had to recruit a fantastic local fabrication shop to get me here though.)
I had them mount the engine, stiffin up the front end and build headers.
Im not home yet to see this in person, but from the photos he sent im COMPLETELY thrilled!
Is there an update on your motor
any updates om your motor? I am curious How things turned out I am almost done with my pump gas motor, its going to be a 598ci with the same heads you have.
Nothing to update.
how bout you start a thread and post up some photos and info on your build while we wait?
well to be honest I have all my parts still in the boxes. I have everything except the pistons and cam for my build I still need to bore the block to 4.600. This is getting very costly. I am still looking at about two grand for pistons and torque plate and gaskets and having the block bored. I bought my heads a month ago and one head was damaged so I sent one of the heads back to pepboys today. I was going to buy heads from lem. But the guy at pepboys give me a hell of a deal That I could not pass up. I could post up some pictures of my parts but that is not the same as showing a build in the process. I am looking around 900hp with the motor. Just trying to get the maximum compression with pump gas. That is the reason I was asking about your build.dirt_worker wrote:Nothing to update.
let me know if you like to see my parts I dont have problem with that. I just need to take pictures of my parts.
What heads did you buy at PepBoys?CHARLIEB wrote:well to be honest I have all my parts still in the boxes. I have everything except the pistons and cam for my build I still need to bore the block to 4.600. This is getting very costly. I am still looking at about two grand for pistons and torque plate and gaskets and having the block bored. I bought my heads a month ago and one head was damaged so I sent one of the heads back to pepboys today. I was going to buy heads from lem. But the guy at pepboys give me a hell of a deal That I could not pass up. I could post up some pictures of my parts but that is not the same as showing a build in the process. I am looking around 900hp with the motor. Just trying to get the maximum compression with pump gas. That is the reason I was asking about your build.dirt_worker wrote:Nothing to update.
Trick Flow PowerPort A460 340 Cylinder Heads for Ford 429/460 TFS-5451T802-M87windsor wrote:What heads did you buy at PepBoys?CHARLIEB wrote:well to be honest I have all my parts still in the boxes. I have everything except the pistons and cam for my build I still need to bore the block to 4.600. This is getting very costly. I am still looking at about two grand for pistons and torque plate and gaskets and having the block bored. I bought my heads a month ago and one head was damaged so I sent one of the heads back to pepboys today. I was going to buy heads from lem. But the guy at pepboys give me a hell of a deal That I could not pass up. I could post up some pictures of my parts but that is not the same as showing a build in the process. I am looking around 900hp with the motor. Just trying to get the maximum compression with pump gas. That is the reason I was asking about your build.dirt_worker wrote:Nothing to update.
Interesting. What kind of deal did you get? Cheaper than summit?
through in a case of royal purple oil with filterwindsor wrote:Interesting. What kind of deal did you get? Cheaper than summit?
Here's whats changed since dyno'ing it last.
Ported heads and manifold
Jomar carb spacer
custom ground cam
Kicked out Moroso box oilpan
External Barnes oilpump
4 vane moroso vacuum pump
Custom built 2.25x4 headers that fit the truck chassis
I've been super busy lately but hoping to re-dyno it and get it back in the truck this spring
Jomar carb spacer
custom ground cam
dirt_worker wrote:Here's whats changed since dyno'ing it last.
Jomar carb spacer
custom ground cam
Any updates on this???
tfsbbf466- Posts : 180
Im getting really close...the truck is almost ready for the engine and new powerglide. Only thing left on it is wiring...engine is a lmost done just finishing up plumbing the new pump and accesories.
Hoping to have it on the roads by the end of June.
Heres a few photos of the new front suspension setup..
And the oilpan modification.
Looking good man now that it's all painted up. I'm curious to see how much weight you dropped up front. Has to be 300lbs or so. Going with a glide this time around?
Yeah, hoping we took 300 off the nose.
The more I thought about it the more the glide makes sense...decided to just bite the bullet and switch now.
The 1.80 1st gear should really help get it off the line..
» 598" ;) A head - Dyno results page 6
» 598 SCJ Build
» 533 Dyno Results
» DYNO RESULTS
» 582 tfs a460
» 598 SCJ Build
» 533 Dyno Results
» DYNO RESULTS
» 582 tfs a460
Page 2 of 6
