Who has any experience with these heads ?
Bill Mitchell Products BMP Cylinder Heads Aluminum Ford Small Block 023015 285cc 64cc 10Degree 2.250" x 1.625
Are these worth installing on a big bore high rpm sbf ?
whitefield- Posts : 2241
Re: Who has any experience with these heads ?
Are those the Manowar heads that require the block too?
I believe they will go onto any Ford block, but they have the extra bolt holes that will work on the Man-O-War blocks.
And speaking of that, is World Products Man-O-War block, the only one out there that features those extra bolt holes??
BBFTorino- Posts : 944
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
