New cylinder heads
+20
Captainp4
steven gregoire
AL Q
557ranger
lghting94
BigRigTech
QtrWarrior
sg86coupe
Gary Blair
Wheelie58
5pointslow
GT300TD
24 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: New cylinder heads
Best I remember the ex-514's were around 100 pounds each so if these are that or less that's good. Having any aftermarket iron head will help a lot of guys trying to compete in the all iron classes.
lghting94- Posts : 762
Todd, these heads are well under 100#. They are similar in weight to a stock head.
schmitty- Posts : 4538
If that's the case that is another advantage because bbc heads are very heavy also. Only problem I am seeing with them is they are coming out about three years to late I no longer need them.
It's never too late to get back in again.
schmitty wrote:It's never too late to get back in again.
I told my wife that, and she mentioned the "D" word if I built another pulling truck....
If the weight aint too big a deal in a build I'd take iron over aluminum. They tend to stay put better.
design
When I originally did the model 3 years ago Mike provided me with an aluminum semi finished version of the Compresco head. It was a lot easier to work with than iron that's for sure. I've had my fair share of grinding 460 iron LOL.
The EX514 and BT Iron CJ are cast off aluminum tooling which allows for thicker cross sections like the deck and other places. That's why they end up being so heavy in iron.
When I raised the valve cover rail 1.25" and desiged 4 individual ports it got heavier for sure LOL. I wanted to be able to use an A-460 intake on the raised port.
The concept I came up with was a sort of plug and play port selection. So when you select a low port the roof will be pretty thick. Now you could also do a raised CJ port as well. I tried to build as much flexability as possible into the design. Sometimes when you ask something to do too many things it doesn't want to. I had a girlfriend like that once. I think this head will do pretty well though.
This head will also have an indistrial application for alternative fuels.
I really wanted to get out to the PRI but I've been a little under the weather.
Gary Blair- Posts : 221
Are these available to buy now? Or when are expected to be available?
557ranger- Posts : 55
Late Jan/early Feb.
schmitty wrote:Saw the new cast iron Eliminator heads at PRI. I will post a few pics when I get home. Mike Bowery said that he can make this head with either the "A" style, or CJ style intake port, and either the chevy or Ford style exhaust. He had a machined head there with the A port and chevy exhaust, that was pretty impressive. These heads all have stock valve geometry, so if you have a good set of pistons already, you will be able to upgrade without having to change them. He said that aluminum versions will be out in the near future also. Another product that is now available from them is a block that can be decked down as low as 9.5".
Would be cool to see a block with gm bell pattern and starter mounting
AL Q- Posts : 83
^ that would make it alot easier to deal with transmissions at the track.
steven gregoire- Posts : 68
Any idea what the cj intake/ bbf exhaust version will flow out of the box?
Captainp4- Posts : 17
lghting94 wrote:Best I remember the ex-514's were around 100 pounds each so if these are that or less that's good. Having any aftermarket iron head will help a lot of guys trying to compete in the all iron classes.
yup 110 each after c n c porting
BOSS 429- Posts : 2367
AL Q wrote:schmitty wrote:Saw the new cast iron Eliminator heads at PRI. I will post a few pics when I get home. Mike Bowery said that he can make this head with either the "A" style, or CJ style intake port, and either the chevy or Ford style exhaust. He had a machined head there with the A port and chevy exhaust, that was pretty impressive. These heads all have stock valve geometry, so if you have a good set of pistons already, you will be able to upgrade without having to change them. He said that aluminum versions will be out in the near future also. Another product that is now available from them is a block that can be decked down as low as 9.5".
the elm blocks have a starter pad on the drivers side already for a gm type bolt on starter
any news on when they will be available?
Now that these have been out awhile, anybody do much work with them? Good potential?
EverySparePenny- Posts : 114
EverySparePenny wrote:Now that these have been out awhile, anybody do much work with them? Good potential?
Who has ran these heads?
Nobody that I personally know of, that's why I ask. They are very intriguing to me.
Sent from Topic'it App
I know a mud racer that bought a set but I don't know if he has them on an engine yet.
68formalGT- Posts : 864
Page 2 of 2 • 1, 2
» NKB CYLINDER HEADS - ANYBODY KNOW ANYTHING ABOUT THEM?
» What does a-429 or a-460 mean regarding cylinder heads?
» AFR 315 Cylinder Heads with Top End.
» Jon Kaase SR71 Cylinder Heads
» WTB - P-51 cylinder heads
Page 2 of 2
