new build of a 40,000 mile 429
67 mustang
Re: new build of a 40,000 mile 429
AndyLeslie wrote:Crank and rods, piston are the same 429/460 I believe. I am rusty on my 385 family interchanges. There are plenty of gurus here. And a few threads I am sure if you search.
Pistons are not the same, only part that's the same is the rods at 6.605
460 used a 3.85 stroke crank and a 429 uses a 3.59.... But they both share the same journal sizes.
And just for in info internal balanced factory cranks will not fit in the late model D9 blocks, but the later external balance cranks will fit in the early blocks
kim wrote:The 429 crank is a shorter through, or stroke. The rods are the same. Ford used a weird piston with the 429 with a very low pin height.
To put a 460 crank in a 429 block, you can use the 460 crank, the rods are the same, and 460 pistons. The bore is the same.
370
Bore: 4.050"
Stroke: 3.59"
429
Bore: 4.360"
Stroke: 3.59"
Chamber size (C8VE/C9VE/D0VE): ~72-75cc
460
Bore: 4.360"
Stroke: 3.85"
Chamber size (C8VE/C9VE/D0VE) 75cc
Chamber size (D2VE) ~99-100cc
Chamber size (D3VE/E6TE): ~93-95cc
What are the compression heights on the 429's and 460's
AndyLeslie- Posts : 57
Piston compression height for stock 429 pistons is 1.89 for stock 460 1.76. Hope this helps.
jeffgfg- Posts : 338
» What are the most cost efficient parts needed to build a 1000 hp stroker motor for a 1/4 mile bracket car?
» 460 should have 500 hp but 1/8th mile calc says I have 300?
» No rules BBF nitrous build - Let's build it
