Lets Talk heat range of spark plugs
kim
gt350hr
t-bird racer
Re: Lets Talk heat range of spark plugs
ngk #8 is what I run.away wrote:I was also told that Auto-lite plugs went to china! So you are probably right.
So what would the recommendation be for a naturally aspirated bracket car methanol injection. TFS street head
We also use #8 in N/A stuff and even in some small nitrous stuff
gmsmkr- Posts : 1364
NGK Spark Plugs R5671A-8 - NGK Racing Spark Plugs
Autozone part number 4554?
Is this the part number?
away- Posts : 266
away wrote:NGK Spark Plugs R5671A-8 - NGK Racing Spark Plugs
Yes
So,
Here is a follow up question. I normally run the -10 with 87 Carb Jets. If I switch to the hotter -8 should I go up a jet
or two to accommodate the hotter plugs??????
t-bird racer- Posts : 192
Fuel should have been right regardless the plugs temp. Most noticable diffrence will be start up. Crisper
kim- Posts : 700
Well I finally was able to make a few passes and the car ran pretty consistent. Here is a picture of the #5 cylinder after my first time run. These are the #8 NGK's. I did have to idle a bit on the way back to the pits. Any and all comments are welcome.
Heat range looks good. Fuel line ok, maybe a little rich. I see a few specs, might want to drop timming a degree or two. Few oxide of n20 fecs.
kim- Posts : 700
Timing is at 31 or 32 degrees. Thanks for your response.
» spark plug heat range
» spark plugs for 466 with 14 to 1 comp
» Plug heat range for a SBF...?
» spark plugs to use
» spark plugs
» spark plugs
