624 C-head
gmsmkr
old blue
624 C-head
Just shareing my build with you guys and would like your opinions and what kind of power it should make, i should be getting bottom end back from machine shop and heads back from performance cnc next week
Premier eliminator block with roller cam bearings
4.5 eagle crank
6.8 eagle h beams with l-19 bolts
4.7 diamond flat tops .043 ring pack
285-305 @.50 846 lift 115
Comp cams solid roller lifters
.045 cometic head gaskets
C460 heads ported by performance cnc
2.45 victory titanium valves
1.86 victory titanium vales
Pac 1248 springs with victory titanium retainers an locks
Jesel 1.8 rockers
C460 motorsport intake
1450 quick fuel dominator (gas)
14.5 compression
4.5 eagle crank
Jesel 1.8 rockers
14.5 compression
old blue- Posts : 124
Re: 624 C-head
Looking at close to 1150 if everything is right! Good luck!
windsor- Posts : 1167
Re: 624 C-head
Depending on who the builder is you could see north of 1200
Re: 624 C-head
windsor wrote:Looking at close to 1150 if everything is right! Good luck!
Thanks windsor, thats what im looking for around 1150-1200
Re: 624 C-head
dfree383 wrote:Depending on who the builder is you could see north of 1200
Thanks dfree, i hope so. Larry sneed at s&g machine is doing engine work
Re: 624 C-head
Isn't he the guy that wrote the JFK assignation book?old blue wrote: Larry sneed at s&g machine is doing engine work
Curt- Posts : 2787
Re: 624 C-head
now that's a motor for a street car with a small tire
Nice build I think you will see the numbers your looking for plus some extra BUT I want some pics of the chassis it's going in cause you know how it is around here
gmsmkr- Posts : 1364
Re: 624 C-head
gmsmkr wrote: now that's a motor for a street car with a small tire
Thanks man, its going im my small tire foxbody. I will take some pix an try to get them up
Re: 624 C-head
6jeff6 wrote:Wow nice I would kill for that!
Re: 624 C-head
Man, that is a serious engine right there!! it will make those small tires work for traction lol!!
Bill
Bill
billandlori- Posts : 2081
Re: 624 C-head
Get ready to hold on lol
larry552- Posts : 335
Re: 624 C-head
larry552 wrote:Get ready to hold on lol
Thats its man, set back, hold on and let her eat
Re: 624 C-head
What did this one make? Updates?
away- Posts : 266
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» P-51 Head's /Head Studs/pushrods (SOLD)
» P51 Head HP gain after head port
