What headers for fox mustang with BBF
cobra501
larry552
Mustang
Putting a BBF into a fox mustang for the first time. Which headers have you guys used that fit nice (ground clearance and around a c-6 or glide). Looking for 2 1/8" headers. Would like single individual tubes where the flange meets the head. Talked with D&D today and they want $899. Will be using a motor plate, aftermarket k-member, and p-51 heads.
Mustang- Posts : 4
Re: What headers for fox mustang with BBF
D&D has about the best shelf stuff you can get.
larry552- Posts : 335
Mike R- Posts : 1381
ACCUFAB made mine. 2 1/8 primary
cobra501- Posts : 95
I have MAC headers on mine but they don't make them any longer.Used would be all you would find.FWIW the front 2 tubes on each side are slip tubes.
Mark Miller- Posts : 1888
Be advised that any of the headers on the market were designed around a specific k-member, engine location, transmission, ride height, etc... If you can find that info out and it matches your car then you're golden...
I've had a set of Dynatech's (made by Mad Dog Headers) and a set of Kook's on my Fox Body. Both collectors hung way too low for my liking. No way I'd be able to street drive it.
For the $900 bucks you'd spend with D&D you can spend a little more and get a nice custom set built...
jbozzelle- Posts : 3705
How bad are the Hooker 6224? I have a set that are ceramic coated. I have heard good and bad.
Bmelton- Posts : 10
Mark Miller wrote:I have MAC headers on mine but they don't make them any longer.Used would be all you would find.FWIW the front 2 tubes on each side are slip tubes.
FWIW the MAC Headers i have,have good ground clearance and i don't think i've ever had them scrape on anything.And that's with 4 cylinder springs on the front,although i do have Aluminum Heads!!!
Mark Miller wrote:Mark Miller wrote:I have MAC headers on mine but they don't make them any longer.Used would be all you would find.FWIW the front 2 tubes on each side are slip tubes.
Also FWIW all i do is pretty much street drive my car haven't had it to the track in way to long!!!
hooker headers
I've been helping on 3 cars with the hooker headers and they perform good on 514 under 800 hp it seems. I used 1 inch body spacers and made my own mounts so engine is level ,not pointing up and that makes ground clearance better, but none had any trouble on the street from too low,
ED468- Posts : 199
If you can do some custom fab like k-member spacers and mounts or plates then you'll be fine with just about any of the headers on the market.
I found that the MadDog headers seem to clear the steering the best.
» a 460 headers for a mustang
» were can i get headers for the 94-98 mustang
» Fox Headers in a '68 Mustang
» 67-70 mustang 429-460 headers
» WTB Fox Mustang 460 Headers
