Opinions wanted on ladder bar shackles
I'm running L&L ladder bars on my '77 F150 4X4 with stock height springs and 35" tires. These have a solid heim up front and U-bolts holding it on the axle tube. This truck is a street rod so off-road articulation is not a concern. Which is better for planting the tires, leave the set-up alone or add shackles to the front? I was reading lots of different forums with lots of opinions but now I'm more confused than when I started. Anybody have a some straight up information? Thanks.
77f150- Posts : 220
Re: Opinions wanted on ladder bar shackles
Stince it's a pavement punder, leave it like it is for the best street traction. If you use it more off road then that is where the shackle deal would be better.
kjett- Posts : 1169
Thanks Karl!
77f150- Posts : 220
Could you post some picture of how you mounted these on the front and rear? I bought a used set awhile back but I havent bolted them up yet.
scottk- Posts : 33
No problem. You need to cut the ears off the factory lift blocks if you have them still as the U-bolts rest beside the lift block and spring:
The mounting plate on the front is pretty straight forward:
77f150- Posts : 220
Thanks,
I was wondering if they mounted on the inside of the block or the outside. I couldnt figure it out with the ears still on the lift blocks. I appreciate the pictures. Any other mods that you needed? How high did you mount your front brackets? Thanks again, Scott
By the way clean truck! I like it!
scottk- Posts : 33
Thanks, she is a loooonnnnggggggg work in progress. I have a SWB frame that is all welded up (all factory holes) and welding the body lift on. When I get everything sorted out I'll transfer all the running gear. In the mean time to answer your question this pic shows the height of the plate on the frame:
77f150- Posts : 220
Perfect! Thank you.
Did you notice quite a bit of difference with them? How is the ride now? Have you noticed any binding?
scottk- Posts : 33
It definately eliminated most of the wheel hop, I can get some chatter once in a while but not bad. Now regarding binding, because it's a pavement pounder I don't work the suspension much so for me it's not bad. I know it's not a great answer but I was prepared for some loss of articulation in exchange for helping with spring wrap.
77f150- Posts : 220
» Opinions wanted.
» Opinions Wanted
» Bellhousings/Opinions wanted
» Opinions or advice wanted
» cam or carb.? opinions wanted
» Opinions Wanted
