PROCOMP HEADS ------ STICKY------
Page 3 of 4 Previous  1, 2, 3, 4  Next
Re: PROCOMP HEADS ------ STICKY------
Post  richter69 on January 30th 2010, 7:17 pm
The chamber is junk to.
Post  The Mad Porter on March 7th 2010, 4:42 pm
Agreed Charlie and Richter..
The procomp exhaust port is actually quite good when properly ported and only when properly ported.
The intake geometry and flow bias suck as cast and can be improved with careful reshaping of the intake port roof, guide trenches and short turn crest. I have managed 360 cfm and more.
The issue is still quality of intake flow and an absolutely terrible combustion chamber design.
A fully worked pair of p/c castings against a good but not max effort pair of not mine Doves was marginally faster with the reduced static c/r of the larger chamber. Add the additional power that the c/r would bring and they are still woefully short of the other aluminum offerings.
Very Happy
The Mad Porter
View user profile http://www.reincarnation-automotive.com
Post  jc10000rpm on March 9th 2010, 9:01 pm
so, is the compression chamber just to big, ??? or do you mean the shape of the chamber is bad ??
jc10000rpm
Post  rmcomprandy on March 10th 2010, 9:07 am
jc10000rpm wrote:so, is the compression chamber just to big, ??? or do you mean the shape of the chamber is bad ??
The chamber just LOOKS pretty awfull because it doesn't have a consistant circular outside shape to it; (like a bunch of connected short flat walls which doesn't adversely affect anything but is not very pleasing to the eye).
Post  cooter on July 1st 2010, 9:04 am
i have no experience with procomp ford heads but have seen horrible casting problems with chev smallblock heads. The chev blocks are no better either with problems in the main cap areas.
cooter
Post  Maddmattmustangs on July 28th 2010, 4:28 pm
Where's the procomp hero Jeremiah? Laughing
Maddmattmustangs
Post  richter69 on July 28th 2010, 5:14 pm
Maddmattmustangs wrote:Where's the procomp hero Jeremiah? Laughing
You cant use ProComp and HeRo in the same paragraph.............
Post  bb429power on July 28th 2010, 5:20 pm
procrap ZeRo
bb429power
View user profile http://michiganmotorheads.forumjonction.com/
Post  Maddmattmustangs on July 28th 2010, 5:59 pm
My bad Embarassed Embarassed Embarassed What a Face
Maddmattmustangs
Post  bruno on July 28th 2010, 8:08 pm
come on guys lets keep this as technical a possible
thxs
Nick Bruno
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  richter69 on July 28th 2010, 9:58 pm
bruno wrote:come on guys lets keep this as technical a possible
thxs
Nick Bruno
aint much technical in a procomp product..........
Post  Maddmattmustangs on July 29th 2010, 9:08 am
thxs
Nick Bruno
Laughing I've heard that on there bare castings the valve guides need honing or complete re machining in most instances. Also the valve seats are recessed far into the port messing with the short turn.
Valves in there assembled heads tend to have wide variations in stem diameter. Widest I've heard of being .060 over what's promoted. The bronze they use also has proven to be weaker than the standard.
Maddmattmustangs
Post  rmcomprandy on July 31st 2010, 10:06 am
thxs
Nick Bruno
Getting the ASSEMBLED heads directly from ProComp is certainly not a good idea.
If anything, the seats are to tall in a BARE casting because a valve job is NOT done to them and that makes for GOOD reshaping possibilities. AND, there are NO valves in a BARE casting.
"Proven" bad bronze...??? I haven't seen it in the over 50 pair I've finished with good hardware. Having bad guide clearance set-up will eat-up anybodies bronze guides.
The "I've heard", my "buddy told me" and a "friend of a friend knows", shouldn't be construed as GOOD information; What you have actually witnessed and done yourself is all that should be discussed here.
Post  jones on November 8th 2010, 5:18 pm
Has anyone come up with a CNC program to correct the flaws in the chambers and ports?
jones
Post  richter69 on November 8th 2010, 5:23 pm
when the CNC program can add material it might be possible............... Very Happy
