Timing chains with torrington bearing
Timing chains with torrington bearing Empty Timing chains with torrington bearing
Post  jbozzelle April 15th 2016, 9:37 pm
Anybody use these? Does the block need machining or is the cam gear machined for it?
Timing chains with torrington bearing Empty Re: Timing chains with torrington bearing
Post  FalconEh April 15th 2016, 11:06 pm
jbozzelle wrote:Anybody use these?  Does the block need machining or is the cam gear machined for it?
I am no expert on this I can only offer the feedback I have received, my understanding is for most no machining is required, but if the bearing fails it is just more tiny parts to be fed through you engine, and there is not a lot of failures due to cam contact with the thrust plate. I would like to hear the Guru's tune in here too as my opinion is that it is a good concept with an expensive and poor execution.
Post  supervel45 April 16th 2016, 3:24 am
I am with Falcon, skip it on a mild build, one more thing to go wrong that can cause big problems when it does for very little to no gain. If it is a roller cam that walks it makes more sense especially on a Chevy. Some of the gears have a recess cut in them to make up the difference and space the chain right but, I don't know about all of them.
Post  maverick April 16th 2016, 3:12 pm
They run 'em with DannyBees and I've heard zero complaints...including with mine. They only question here is if you feel you need one or not.
Post  Curt April 16th 2016, 7:31 pm
We've always ran them with no problems. It's like anything else. You can't expect it to last forever.
Post  Gregaust April 17th 2016, 2:37 am
The Ford racing roller thrust requires the back of the cam gear machined
Gregaust
Post  jbozzelle April 17th 2016, 10:57 am
Thanks. Was just curious. Saw them when looking for a chain for this budget 351 build I've got going on right now. Saw chins with the Torrington bearings and bronze thrust washers...
Post  jbozzelle April 17th 2016, 11:17 am
Also, since this is just a mild street engine using the stock cam retainer plate should I run a cast iron cam gear because the billet steel gear will chew into the cam retainer plate?
I should be looking for a cast iron cam gear timing set, or use a timing set with the billet steel gear and bronze thrust washer?
I'm honestly confused here.  On my 514 I'm using a bronze cam retainer plate and the FRPP timing set with billet steel gears.  I just recall someone mentioning how the billet steel gears will chew the retainer plate, etc...
Reason I'm confused is I want a true roller chain with a 9 position crank sprocket. But then it gets confusing with the billet gears, Torrington bearings, bronze washers, etc.
Post  rollercam1 April 17th 2016, 12:07 pm
I have ran the Torrington bearings in all of my engines for the last 15 years. The summit brand true roller kit is made by SA gear, as with most of the other brands and you can't go wrong. There is a roller bearing set up from them as well. All small block fords that were factory roller cams, are steel cams. So, don't be worried about wearing the thrust plate. If you go to a roller setup, you won't have to worry about it anyways. It's the little stuff that helps build HP
rollercam1
rollercam1
Post  Lem Evans April 17th 2016, 12:07 pm
If you have a cast flat tappet cam.....iron cam gear, iron diz gear, iron cam retainer plate. Simple and cost effective.
Post  69F100 April 17th 2016, 1:00 pm
I am running one on my 552 it is a comp cam true roller with the bearing it fit fine I didn't have to do any machine work
Post  supervel45 April 17th 2016, 1:27 pm
Lem Evans wrote:If you have a cast flat tappet cam.....iron cam gear, iron diz gear, iron cam retainer plate. Simple and cost effective.
That is the way I look at it to. Leave all the billet and roller stuff for racing engines.
Post  supervel45 April 17th 2016, 1:28 pm
That is the  way I look at it to. Leave all the billet and roller stuff for racing engines. with heavy spring pressure that can actually benifit from it.
Post  jbozzelle April 17th 2016, 2:42 pm
Thanks Lem! That's the info I needed. I have a cast cam core (hyd roller) and the original cast retainer plate. And I think summit makes a cast cam gear set with a 9 position crank gear.
