Edelbrock Package for Towing Engine
+6
zbob
longroofracer
RustyBolts
10 posters
Re: Edelbrock Package for Towing Engine
Mark Laczo wrote:Rusty bolts,
If you are on a budget it would benefit you to use a vender that is close to you where are you located. On the other site Scotty J had a thread titled
"RHP 521 truck high torgue build. 500HP, 600 ft/lbs"
It details what is required. This may help you some. It just shows you don't need the aftermarket aluminum stuff unless you want to.
FWIW Mark
Do you have a link because I couldn't find it.
jasonf- BBF CONTRIBUTOR
RHP build
No link.
I actually printed a hardcopy out (because I like to keep hardcopies and keep all kinds of paperwork) Jan.24/2006 from an original Network 54 post Oct.15/2005.
This 521 build may be listed on Scott site.
FWIW Mark
FWIW Mark
Mark Laczo- Posts : 274
Lem just did a 501 1/2 the other day I will see if I cand find it for you, killer build.
» 500 plus cfm A460 HEADS
» Advice For Engine For Towing
» Help needed with ring package
» How much crap to make a E4OD work behind a towing 460 based engine??
» SR71 and Godzilla...
