Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
+40
Rich Osmond
J.Toney
CDMBill
Straubtech
521swbford
glenevans
gmsmkr
Dark Horse of Apocalypse
tfsbbf466
Dave C.
Price5113
CHARLIEB
bb429power
bigjohn2007
droppedf100
valleydawg
njstang87
61coon
norm
56Tbird
Dave Maxwell
ThndrChkn
Barney
dirt_worker
44 posters
Page 3 of 6
Page 3 of 6 • 1, 2, 3, 4, 5, 6
Re: Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
Interesting. What kind of deal did you get? Cheaper than summit?
windsor- Posts : 1167
through in a case of royal purple oil with filterwindsor wrote:Interesting. What kind of deal did you get? Cheaper than summit?
CHARLIEB- Posts : 145
Here's whats changed since dyno'ing it last.
Ported heads and manifold
Jomar carb spacer
custom ground cam
Kicked out Moroso box oilpan
External Barnes oilpump
4 vane moroso vacuum pump
Custom built 2.25x4 headers that fit the truck chassis
I've been super busy lately but hoping to re-dyno it and get it back in the truck this spring
Jomar carb spacer
custom ground cam
dirt_worker- Posts : 535
dirt_worker wrote:Here's whats changed since dyno'ing it last.
Jomar carb spacer
custom ground cam
Any updates on this???
tfsbbf466- Posts : 180
Im getting really close...the truck is almost ready for the engine and new powerglide. Only thing left on it is wiring...engine is a lmost done just finishing up plumbing the new pump and accesories.
Hoping to have it on the roads by the end of June.
Heres a few photos of the new front suspension setup..
And the oilpan modification.
Looking good man now that it's all painted up. I'm curious to see how much weight you dropped up front. Has to be 300lbs or so. Going with a glide this time around?
Yeah, hoping we took 300 off the nose.
The more I thought about it the more the glide makes sense...decided to just bite the bullet and switch now.
The 1.80 1st gear should really help get it off the line..
Yeah it definitely will especially if you decide to hit this motor with a little spray. I think your problem hooking before was due to the rear suspension set up mostly. It should work great now. Was your last c6 std ratio or the e4od gear set?
I think the soft sidewalls were more the prob than the suspension. I did have the e4od planet in it though.
Since I plan on racing it with Dot tires and 1000hp I feel the pg is a wise choice.
It should really calm things down ALOT!
dirt_worker wrote:I think the soft sidewalls were more the prob than the suspension. I did have the e4od planet in it though.
I think so too. Good luck and keep us updated.
res0rli9- BBF CONTRIBUTOR
res0rli9 wrote:update
X2
Dark Horse of Apocalypse- Posts : 171
Its getting close guys...
Heres a few photos of my progress.
Looking good...
Now give an update on the new dyno #s
This thing looks great I could only imagine what it will feel like riding in that thing!!!
gmsmkr- Posts : 1364
res0rli9 wrote:Looking good...
Patience fellas...ill update w numbers as soon as I get it off the dyno. (I only put it in the truck so I can mount/plumb the wetvac pump and alternator. Then its back out to dyno and final assemble.
I a single dad....own/operate a small business and have tons of other stuff goin on besides this build so please bear w me
Im MORE than pleased at how well this thing has turned oout.
Trust me...I cant wait to start it snd do a burnout!
dirt_worker wrote:res0rli9 wrote:Looking good...
What ya got as of yet looks awesome.
Front drive and plumbing is complete!
Dynoing tuesday, updates to follow
So looks like you went with a peterson widevac instead of the seperate oil and vac pumps?
Yup... I have a nice 4vane moroso vaacum setup and a Barnes oil pump Id part w if anyone is interested
Page 3 of 6
